Results 1 to 3 of 3
Thread: help please.
    Jul 2008
    1987 HATCH LX-i
    mesa, az
    Exclamation help please.
    hey guys. im new to 3 geez.
    ok heres what happened, i was making a tight u turn, my tires slid on some dirt and when they caught to road again i went into a curb hitting the front left tire....i know.. im an idiot.
    after this i noticed that my steering wheel was off center, to the left. And it pulled to the right a little more than it did before.
    also i started hearing a rattling sound from the front left area (the same place i smashed into the curb.) when i accelerate from a stopped position.
    i know that i hit the tire because my rim has pretty big scratches on it.
    i also get a rattling sound when i turn hard to the left or right. but that existed before this happened. ive read that its caused by the cv joints or the axles. i dont know if this is related or not
    any help would be awesome. how to fix it, or what i need to do
    thanks guys, peace
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Re: help please.
    chance are that you have bent or broken something and thrown the alignment way out
    put it up on stands and pull the wheel off and check it all out
    you'll be able to compair it to the other side to see if anything is bent.
    use a bar or something to lever on things,just not to hard and you should find what it is thats buggered
    get the wheel checked for true as well
    Re: help please.
    In USA most people making a hard U turn are turning left, how did you hit the left side on the curb?
    Most likely you need cv joint work, and suspension parts could have been damaged. A nice bruise on a tire will make it pull hard too.
