Originally Posted by
guyhatesmycar
You should PM me some details on that Hedman unit, it almost looks like a solution to my problem. I have about 2.8" between my front x-member and the front pan rail on my EL engine, which would seem to be enough to snake exhaust through. My concern is that the pan rails on the B20A are spread wider than mine, and there won't be any room once that engine's in.
If I can tuck the exhaust right up against the engine, I might just get away without other modifications.
Are you altering the angle of the header in relation to the head, or just the downpipe? Looks like you're gonna be close to the pan, might wanna incorporate some sort of heat shield like I'm thinking about.
