Results 1 to 13 of 13
Thread: adjusting the carb
    1990 Honda Accord Ex 5spd.
    Knoxville, TN
    adjusting the carb
    I have a 82 honda civic. (1500cc). We sent the car to get looked at because it wouldn't start up after we did a tune up.. it died even before we did the tune up, but it needed it anyway. It would work for a little bit after the tune up, but it sounded like we put the plugs on wrong.. (which i dowbt could happen because we numbered and did it one by one...) So anywho, we brought it to a mechanic who said that the timing was off and the carb was "tired". So he re did it. Well when i was driving it home it didn't have any of the power it used to have. Slower than snot. So when my grandpa came (he's been working on cars forever) he took a look at it and said the carb was not adjusted right. Now i'm wondering, since it looks like i might have to bring it to honda, how easy is it to check and adjust the carb? I have mild experiance with working on cars. I could use a haynes manual, but i havne't seen one around. Is there a similar year to mine that i could just read off of?
    "If you were paying attention DANIEL you'd know the Nintendo's pass threw everything!"
    - Col Jack O'Neal - Stargate sg-1.
    Oct 2001
    87 Accord EX , 5spd , Manual
    try checking the carb faqs and howto's the FAQ and how to sections and see what you can get !
    does it hesitate when you floor it while driving ?
    MIKE
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    82 Honda Civic (1488cc) 1.5 L - 3bbl Keihin.
    Knoxville, TN
    no hesitating. It does have a big problem though taking off and accelerating. Also it's just not as fast as it used to be.
    Oct 2001
    try messing with the A/F mixture screw ! don't know where it is on the civic !
    MIKE
    shepherd79's Avatar
    Falling Waters, WV USA
    take it to honda dealer. if it doesn't work after that play with it on your own.
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I would take it to the dealer.
    Oct 2001
    sorry i haven't thought about the dealer thing while i don't have a dealer here !
    MIKE
    A20A1's Avatar
    Sep 2001
    how did he adjust your timing?
    Knoxville, TN
    I didn't do the timing. We sent it to a guy and he fooled around with it. He noticed that after he put on a new carb that the timing was off so he said he adjusted it. I dont know what he did.
    A20A1's Avatar
    Sep 2001
    the new carb should not effect ignition timing, unless ithe carb was not set prpoerly or it has a leak...
    Since manifold vacuum changes the amount of timing/ignition advance, but it does not change the base timing... if the carb was not working properly or there was a vacuum leak, then manifold vacuum would be low and ignition/timing advance would be less... you would notice lack of power and slow acceleration.
    The best thing to do is set the distributor to its proper igniton timing. normally that means you have to have access to a timing light and a shop manual for your car... within the first few sections there is a page on setting timing.
    Once that is set up right and if power is still bad, check for vacuum leaks and make sure the carb is set properly... like the float level and air fuel mixture screw... also unhook the vacuum line at the distributor end and hook it to a vacuum guage. you should read between 18" - 22"
    if everything is ok and your idle speed is fine... then advance your distributor... turn it about 3mm counter clockwise. lower your idle speed as needed.
    put a weber 34/36 progressive on that bitch!! :super:
    Eric
    A20A1's Avatar
    Sep 2001
    Are you getting the 38 from PAUL... he said he's puting one on his B20..
  1. help adjusting idle! and....
    By Kagato in forum Carburetor Tech
    Last Post: 08-02-2008, 09:39 PM
  2. Help adjusting rebuilt carb.
    By iron in forum Carburetor Tech
    Last Post: 03-20-2005, 05:52 PM
  3. Adjusting valves?!?!
    By InfinityAudioLXi in forum 3geez Accords
    Last Post: 10-12-2003, 04:54 PM
  4. Adjusting Mixture with carb on car?
    By ascender in forum Carburetor Tech
    Last Post: 03-19-2003, 05:13 AM
  5. Adjusting the Carb
    By goldyaccord in forum Carburetor Tech
    Last Post: 10-16-2002, 08:31 AM
