Alright basically here's the story... I installed a weber 32/36 carb about 3 weeks ago and for some reason theres a gas smell in the mornings when I turn it on!!! so basically the gas smell occurs when I turn off the car... because every time i get inside to turn on the car I can smell gas!!! I've taken apart the carb assembly and tighten all the bolts so the smell is deffinately not coming through the carb adapters??? what could this be??? can't see no visable gas leaks and it doesn't show on the gas gauge???
