I finally fixed many major problems with my 88 LXI, but it still has a funky idling problem.
I set the idle right around 800rpm with the A/C off and everything is good. I get in the car the next morning and drive to work and the idle has gone back up to around 1200 rpm?!?! Is there something I am not doing? Do you have to put the ECU into a mode on the 88 and 89s to set the idle like you do on 89 preludes? (jump wire to set idle)
Fast idle valve is good
I am replacing the ECU temp sensor
no vacuum leaks
IACV seems to be fine
Coolant level is good
