Results 1 to 6 of 6
Thread: Engine breather
    Aug 2008
    Toronto, Ontario
    Engine breather
    I think that what its called. The mini air filter looking like thing that you install off the top of the engine. What are the beneifts and is it worth putting on?
    Re: Engine breather
    really none except if your modding your intake to were you cant have the air suction hose .. correct me if im rong anyone
    LX User OldSkoolA20accord's Avatar
    Apr 2008
    88 Accord DX
    limestone, TN
    Re: Engine breather
    i replaced the one on my car and it made it run a little better. it was black. it just vents the valve cover.
    I would replace it. the advance auto guy told me it helps mpg too.
    88 DX hatch.
    Re: Engine breather
    I saw no difference when I had mine installed, I went back to suction hose when I did my CAI
    Re: Engine breather
    Quote Originally Posted by jduncan View Post
    https://www.3geez.com/forum/showthrea...t=oil+breather picture is on post #227.
    Besides the CAI you can use one to keep oil (blowby) from getting back into your intake system.
    Re: Engine breather
    all that is, is filtered air being pulled through the pcv system. if you want to make an improvement,make sure your pcv valve is working and all the hoses are in good order. including the one off the back of the oil pan. there should be a negative pressure at that breather anytime the vacume is high enough to open the pcv valve.
  1. oil breather
    By 2ndgenludedude1986 in forum 3geez Accords
    Last Post: 05-05-2004, 07:13 PM
  2. what is a breather?
    By dub88acc in forum Classic Honda Community Chat
    Last Post: 02-10-2004, 08:48 AM
  3. Breather Filter
    By 88LX-iSedan in forum Performance
    Last Post: 05-02-2003, 06:19 PM
  4. K&N Breather???
    By Haolerot in forum 3geez Accords
    Last Post: 11-10-2002, 05:41 PM
  5. Breather Filter
    By Site in forum Performance
    Last Post: 08-08-2002, 06:22 AM
