Results 1 to 2 of 2
Thread: AC pressure at idle vs higher RPMS
    LX User 88accordlxcarb's Avatar
    Jan 2003
    '88 Accord LX(carb)/'92 Infiniti G20/'00 Infiniti I30/'88 Oldsmobile Cutlass Ciera(286,000 miles), 2004 VW Passat, Golf Cart...
    Middle Georgia
    I feel stupid asking this question...
    At idle with my AC running i am sitting around 35 PSI.
    When i rev the car (or, i assume, when i am driving), the pressure goes to around 15 PSI.
    Assuming this is not normal, do you think my expansion valve is not functioning correctly or is the pressure supposed to change with engine speed?
    Millington, TN
    Re: AC pressure at idle vs higher RPMS
    How are you checking the pressures, gauge valve closed or open (Should be in closed postion).
    Sounds like you have a low pressure issue. At 35 psi clutch cycles but pressure drops 15 psi disengaging clutch.
    Phil
  1. Rough idle and rough in high rpms
    By Tread in forum Carburetor Tech
    Last Post: 11-12-2011, 07:37 AM
  2. HiGhEr rPm'S
    By troutz15 in forum Performance
    Last Post: 07-22-2004, 12:59 PM
  3. Adjusting idle rpms
    By SLCPUNK in forum Carburetor Tech
    Last Post: 11-21-2002, 12:30 AM
  4. higher than normal idle and rpm differences
    By mgirl69 in forum 3geez Accords
    Last Post: 11-20-2002, 10:30 PM
  5. a/t high pressure side vs low pressure
    Last Post: 07-12-2002, 10:01 PM
