Page 2 of 9 FirstFirst 123456 ... LastLast
Results 26 to 50 of 201
Thread: Mad JDM dash yo!
    2ndGenGuy
    Guest
    Re: Mad JDM dash yo!
    My 81 has the same problem where the brake light indicator comes on occasionally. My guess would be bad grounds from the socket to the common ground wherever that is. Probably not enough juice getting to the ground for the light out system to know there is a bulb there. Probably also why I seem to get dimming lights when I hit the brakes.
    LXi User 79cord's Avatar
    Melb, Aust.
    My brake warning light used to come on occasionally also but would readilly go out after some wiggling of the bulb & socket, supporting the bad earth conclusion.
    Low oil pressure light doesn't sound good, sometimes light oils or low idle speeds can cause them to come on though.
    Plated dash vents makes me think of Dads Lancia Flavia whose plastic vents were plated gold for the wood panelled background of the dash.
    When I had the problem, I did everything I can from replacing new bulbs to replacing the ground. The problem goes away when I replaced the warning unit in the cluster.
    LX User haridev's Avatar
    Aug 2008
    81' Accord EX
    Ipoh, Malaysia
    well, my cluster did not work for 10 years then suddenly decided to work after i replaced the speedometer cable. this proves that the cluster is indeed very sensitive. however i suspect that there may be many factors which may cause this issue. the cluster itself maybe on of them but bulbs and bad grounds maybe another theoratical cause. anyway apart from an annoying red light on the screen i suspect that it shouldnt be all so bad. regards to all.....n hazwan...good luck on ur dash....
    life is only what you make of it...
    my dad with our 81' accord...
    Honda Accord 1981
    Mercedes 190E 1988
    Volkwagen 1200 1971
    MSN: [email protected]
    YM: [email protected]
    The brake light sockets on my '76 had leetle plastic saucers with a hole in the middle of them. The saucers allowed the positive electrode to stuck through the hole and kept it from shorting to the negative side of the socket. Over time, the saucer turned to dust and blew away, leaving me with no brake lights.
    Really easy fix. Really hard to find.
    Aug 2008
    81' Accord EX
    Ipoh, Malaysia
    i still do not get why the need for such a sensitive system. just dont need it...more automation = more complex. think simple...
    Honda Accord 1981
    Mercedes 190E 1988
    Volkwagen 1200 1971
    Finally!
    Sprayed with Duplicolor truck bed coating which suprisingly has similar rubberized texture to stock the stock dash. I'll see how it holds up with the cracks and all. Sorry no in progress pics
    wow that looks super sexy!!!!
  9. #34
    Defrost vents and glove box are done.
    Waiting for the clock trim peice expoxied before I could paint.
    BTW the dash isn't that glossy. For some reason it became glossy as hell with the flash.
    did anyone figure out what that light may be that everyone thought was the choke, I reckon its a "Speeding" light that comes on when you go over 100km/h
  11. #36
    2ndGenGuy
    Guest
    Man that looks great! That chrome, just so sexy. Chrome + black = awesome!
  12. #37
    Oh yes they are sexy indeed! Still waiting to get my gauges done. It would look sexier with painted needles and blue LEDs. I wish I could do it in amber
    Aug 2008
    81' Accord EX
    Ipoh, Malaysia
    hey hazwan. dude..... if i said i was in shock, would be an understatement. i loved the way the dash looked in the end. it looks brand new! do use tuff stuff for all the other plastic parts/ inserts in the centre console. and for the meters as well. i think it would really bring out the final finish! now i am jealous of ur dash. the chrome!!! dont be surprised if i break into ur car to steal ur dash! haha!
    as for the light above the door warning cluster. i read an article which said its meant to flash for 6 seconds before indicating whether the trunk or doors are open or the brake lamp is blown.
    cheers!!
    p.s. do post pics of the progress
    Honda Accord 1981
    Mercedes 190E 1988
    Volkwagen 1200 1971
  14. #39
    lol its far from being perfect or new but its 100x better than what I have in the car right now.
    I cleaned all the air vents and ducts and painted all misc plastic bits with Krylon Fusion plastic paint. Everything is cleaned one by one so it should be good
    Can't wait to get rid of this:
    Well, I might redo this one as well and sell for profit lol.
    new dash ftw
  16. #41
    =O!!!!111 OMFG!! SEX!!!
  17. #42
    LX User Lil Mike's Avatar
    Toronto, Ontario
    that looks amazing good work
    thanks mkymonkey
  18. #43
    Wow! That looks way awesome. Well done!
  19. #44
    [IMG ]http://img.photobucket.com/albums/v197/ullyeus/accord/jdm_dash/DSC00013.jpg[/IMG]
    [IM G]http://img.photobucket.com/albums/v197/ullyeus/accord/jdm_dash/DSC00015.jpg[/IMG]
    do red leds
  20. #45
    do red leds
    I can't The gauge face has green thinggy under it instead of using green rubber stuffs on the bulbs. The only color that can go through the green are blue, green and white - which will lit up the gauge green Tried red and amber and it won't even light up.
    aw i know i could make my 3gee cluster light up red and it had the green in the lens too but they must have used a darker green in the 1gee
  22. #47
    Aug 2008
    81' Accord EX
    Ipoh, Malaysia
    hey man.....i too would like to turn my gauges blue. as for red i would encourage. the 1st issue is that like in the proton waja (Impian in UK) red gauges tend to be annoying when driving long distance. at least on the accord it can be dimmed. however it also has a lot to do with personal preference. as for me from what i noticed on the old E28 BMWs, old gauges with older bulbs tens to look dated after a while. well, do let me know how it turns out and remember pics!pics!pics!
    regards, dev
    p.s. happy studying and fasting
    Honda Accord 1981
    Mercedes 190E 1988
    Volkwagen 1200 1971
  23. #48
    Older pics of the blue LEDs (crappy pics)
    Made my own faces later on.
    Both are kinda dim and I'm going to use superbright blues this time.
    Wish I could do it in amber as that would match the car's theme.
    Aug 2008
    81' Accord EX
    Ipoh, Malaysia
    well the sad thing with older cars, the lights in the meter cluster reflect of the faces of the cluster rather than from being coming out from the back of the cluster out. i hope you get it. anyway, i think that you should try to take a pic with the green OEM lamps in the cluster. but the white faces would look nice. however i really liked the white to yellow band on the speedo. if your not using the new cluster i might take it off your hands ;-) by the way all this is my dad's advice. do try the green, then if it doesnt work for you, go for the blue. i always though that the green dash lights were the signature for the old 1geez. remember pics pics pics....cya...
    Honda Accord 1981
    Mercedes 190E 1988
    Volkwagen 1200 1971
  25. #50
    Quote Originally Posted by haridev View Post
    The lights on the top of the gauges are there just to lit up the needles as they wont lit up on its own. They do have regular bulbs at the back for the faces. The same design stayed for a while. I think they stopped it in 5g or 6g Accord/Hondas.
    The problem now with 1g Accord, instead of using green rubber thingy (condom lol) the back of the faces are green colored thus making any color change nearly impossible. I'm bored with the green plus I want it to match my headunit (blue+red).
    The cluster won't be finished until I went back for the holidays as I can't seem to find any electronics store over here I'll get the dash installed tomorrow morning though Can't wait!
  1. While the dash is out???
    By King Peetis in forum 3geez Accords
    Last Post: 06-13-2009, 11:38 AM
  2. Dash, Dash lights, clock, turn signal all not working?
    By Josh89accord in forum 3geez Accords
    Last Post: 09-06-2008, 07:45 PM
  3. behind the dash
    By lightbulblxi in forum Classic Honda Community Chat
    Last Post: 01-21-2004, 10:10 AM
  4. How To Take Out Dash
    By kustom89lxi in forum Interior & Exterior Care
    Last Post: 09-08-2002, 05:14 PM
  5. in-dash DVD
    By 89cordlx in forum Interior & Exterior Care
    Last Post: 09-03-2002, 07:09 AM
