Page 20 of 22 FirstFirst ... 1016171819202122 LastLast
Results 476 to 500 of 533
Thread: My Hoopty
  1. #476
    Re: My Hoopty
    Elaborate!
    Also how did you mount that trigger wheel?
  2. #477
    Re: My Hoopty
  3. #478
    Re: My Hoopty
    You need taller jackstands those are sinking from the car sitting so long!
  4. #479
    Re: My Hoopty
    Hi Walt!
  5. #480
    Re: My Hoopty
    Hi Walt!
    I did take the Scout off mine finally.
  6. #481
    Re: My Hoopty
    Is it uh safe to mount a large spinning hunk of metal to a large spinning hunk of metal with a 3d printed part?
  7. #482
    Re: My Hoopty
    What is Prototyping? Definition, Types, Qualities and more - GeeksforGeeks
  8. #483
    Re: My Hoopty
    Ok, yeah I guess it is on jack stands doing the opposite of running
  9. #484
    Re: My Hoopty
    Congrats! Did you drive somewhere cool?
  10. #485
    Re: My Hoopty
    No heck it wouldnt start again. The wiring has finally gone south I think, Its getting the toggle switch, starter button treatment.
  11. #486
    Re: My Hoopty
    No.
    Yes!
    Gotta keep the old distributor because the ECU needs the crank sensor inside it.
  12. #487
    Re: My Hoopty
    Son, you need to get that handled.
    Like so:
    Or so:
  13. #488
    Re: My Hoopty
    About halfway there...
  14. #489
    Re: My Hoopty
    What's up with the power steering pump?
  15. #490
    Re: My Hoopty
    It's gotta move. The trigger wheel uses the PS pulley. The sucky thing is that I have to add an idler pulley if I don't want the belt to slip. The complexity of the project just doubled.
  16. #491
    Re: My Hoopty
    Hmm. I see that. Why not an electric pump then?
  17. #492
    Re: My Hoopty
    'Cause I could K20 swap for cheaper LOL.
  18. #493
    Re: My Hoopty
    Anyone know why the accessory brackets are so massively overbuilt on this engine? The PS and AC brackets are serious chunks of cast steel. It's like they were built for a 700HP engine.
  19. #494
    Re: My Hoopty
    They are pretty serious casting....
  20. #495
    Re: My Hoopty
    Looks centered to me. If I'm wrong, the broken belts will tell me.
    Version 4.0
  21. #496
    Re: My Hoopty
    So AI is pretty cool. I learned that I need 60% of belt contact to turn my pulleys reliably. I'm closer to half that without an idler pulley. I also learned that I need one of these get good alignment:
    https://www.oreillyauto.com/detail/c...ice/gate/91075
    Always more to do...
  22. #497
    Re: My Hoopty
    Grooved belts will walk if there not aligned well. It will tell you pretty quick.
  23. #498
    Re: My Hoopty
    If you know of a way to verify pulley alignment that doesn't involve a $200 tool, I'm all ears LOL.
  24. #499
    Re: My Hoopty
    Straight edge or a level?
    Oddly my co worker at work old Ford pickup shreaded the belt twice. We had to shim the power steering pump a little or the belt would run off a rib.
    After 22 years who knows why.
  25. #500
    Re: My Hoopty
    Attach a laser level to your straight edge
  1. First post, the hoopty... ;)
    By only8v in forum Classic Honda Pics & Videos
    Last Post: 03-13-2008, 06:56 PM
