Elaborate!
Also how did you mount that trigger wheel?
Elaborate!
You need taller jackstands those are sinking from the car sitting so long!
Hi Walt!
Is it uh safe to mount a large spinning hunk of metal to a large spinning hunk of metal with a 3d printed part?
Ok, yeah I guess it is on jack stands doing the opposite of running
No.
Yes!
Gotta keep the old distributor because the ECU needs the crank sensor inside it.
About halfway there...
What's up with the power steering pump?
It's gotta move. The trigger wheel uses the PS pulley. The sucky thing is that I have to add an idler pulley if I don't want the belt to slip. The complexity of the project just doubled.
Hmm. I see that. Why not an electric pump then?
'Cause I could K20 swap for cheaper LOL.
Anyone know why the accessory brackets are so massively overbuilt on this engine? The PS and AC brackets are serious chunks of cast steel. It's like they were built for a 700HP engine.
Looks centered to me. If I'm wrong, the broken belts will tell me.
Version 4.0
So AI is pretty cool. I learned that I need 60% of belt contact to turn my pulleys reliably. I'm closer to half that without an idler pulley. I also learned that I need one of these get good alignment:
https://www.oreillyauto.com/detail/c...ice/gate/91075
Always more to do...
If you know of a way to verify pulley alignment that doesn't involve a $200 tool, I'm all ears LOL.
Attach a laser level to your straight edge
