Results 1 to 11 of 11
Thread: How To Adjust My Clutch
    Dec 2006
    1989 Accord LX & SEI
    Springfield, VA
    does anybody know how to adjust a cable clutch... my clutch you basically have to let the whole clutch out for gear to engage!!!
    Dec 2003
    Millington, TN
    Re: How To Adjust My Clutch
    There is a black slotted knob at the clutch cable bracket on the tranny housing. Now you should have a small rubber lock tab at the bottom of that knob.
    Depress the lock tab rotate the knob clockwise to tighten until you have about a 1/4 inch of play.
    If you don't have the rubber locking tab at the bottom of that knob, the adjustment won't stay after you engage the clich pedal a few times you will loose the adjustment.
    Phil
    Dec 2008
    MA
    piccss?
    huge transformation.
    you can download the manual.....just make sure to do it when the engine is cold....i burned my hand on the upper radiator hose...trying to adjust my clutch
    like messy said when cold or you well have a burnt arm. Down is tighten and up to loosen. so if your knob is in the middle or even 3/4 to the top go half and try it. an so on.
    Gentlemen. Gentlemen. Have we learned nothing from this board?
    This is the proper way to adjust a clutch:
    LMFAO. holly shit snooz. Vise gripz is one of the best ways also
    Dec 2008
    MA
    sweet. thanks guys
    You want slight play in the arm.
    DX User clark_486's Avatar
    Apr 2008
    1986 Accord DX
    Maine
    :d
    http://www.cardomain.com/ride/3052003
    1986 USDM Accord DX
    Quote Originally Posted by clark_486 View Post
    :d
    Have to give credit to Clark for that priceless pic. Original thread is here:
    The proper way to adjust your clutch
  1. how do i adjust the clutch pedal engagement point
    By gsus in forum 3geez Accords
    Last Post: 01-04-2005, 01:13 PM
  2. Where do you adjust RPM Scale?
    By AccordAddict in forum Performance
    Last Post: 07-18-2004, 02:39 PM
  3. How Do I Adjust E-brake And Clutch?
    By mattalica in forum 3geez Accords
    Last Post: 03-08-2004, 03:26 AM
  4. Ways to adjust clutch???
    By BlueSpecV03 in forum 3geez Accords
    Last Post: 06-13-2003, 01:16 AM
  5. What Do I Adjust the Clutch With?
    By jigga225 in forum 3geez Accords
    Last Post: 08-08-2002, 06:37 AM
