Results 1 to 8 of 8
Thread: Headlights stuck up?
    Jun 2008
    -87 Accord lx
    I was driving the other day and i noticed that when i turned my car off and the headlights off that they both stayed up. The switch in the car that flips up the headlights isn't on either. The headlights still turn on and off, just not down.
    I'm thinking its electrical because both motors wouldn't fail at the same time. Maybe a fuse? Or bad wire?
    Re: Headlights stuck up?
    check the fuses.. if its not that its most likely the switch... mine was bad when i got my car i switched it out and they work fine now
    If they're stuck up, ridicule them. That will bring them down a peg or two.
    Jun 2008
    Where is the switch? The one on my dash?
    the switch may be faulty. thats the usual case for this problem. pull it out and make sure its plugged in properly (the headlight up down switch that is.
    Theres a relay box that drives them both. Scary but I think it evens says headlights on it. Its under the dash I think driverside.
    Quote Originally Posted by bhad133 View Post
    yes the dash switch... its the cause of the problem 85% of the time
  1. oil pan stuck
    By likewtf in forum 3geez Accords
    Last Post: 01-30-2012, 07:23 PM
  2. Stuck!!
    By oldman in forum Newbie Introductions
    Last Post: 12-10-2011, 06:33 PM
  3. Stuck in the mud
    By halxi in forum Classic Honda Community Chat
    Last Post: 08-20-2006, 11:46 PM
  4. stuck bolts
    By 89accordboi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-04-2003, 04:43 PM
  5. oil pan stuck
    By mzabeefy in forum 3geez Accords
    Last Post: 12-01-2002, 06:17 PM
