Results 1 to 17 of 17
Thread: Frickin Antannnnna
    LXi User 1989se-i's Avatar
    89 Accord SE-i Coupe
    Jokelahoma
    Frickin Antannnnna
    Does anyone know how to pull the power antana out?
    Performance Modz: Short Ram Air Intake, Custom Exhaust w/o Cat & Resonator, Cherry Bomb Turbo Muffler, Accel Coil, Removed AC
    Other Modz: Clear Blinkers, Purple Calipers, Accord Emblem On Dash, Winking Headlights
    Oct 2001
    87 Accord EX , 5spd , Manual
    man you got in the same problem like i did ! my antenna just stopped working ! the motor is located above the fuse box under the dash , so you have to get it out ! it's a real mess i just left till i have time !
    MIKE
    Jokelahoma
    Damnit, I like retractable antannas too. How much is a new (from salvage) one?
    My radio sucks with the thing retracted.
    Oct 2001
    what does it do ? does it click or it does't do a thing !
    the best thing is to get it from the junk yard! and take a 9 V battery ( small one ) to test the one in the junk yard !
    i don't know how much it costs ! sorry !
    MIKE
    Jokelahoma
    Well, heres the thing: When the other people owned it, the hood flipped up when they were on the highway and smashed the rood, and antana. The antanna snapped, so i cut it and jb welded the tip on there, so it looks retracted.
    Yea, it does click too
    Oct 2001
    so you have no antenna ???
    MIKE
    Jokelahoma
    Basically.... no
    I cut all but 1" off. Then,I cut the very tip off (the part with the little ball thing), then glued that to the 1" thats sticking outta the base.
    Does that make any sense at all? :/
    Oct 2001
    so now you need a new wire to insert into the antenna place ! right ? if so i would recommend going to the junk yard and try to find the whole assembly ! or at least the wire ( you said the motor makes a clicking sound which means it's working ! )
    MIKE
    Jokelahoma
    Thats what i was afraid of
    Ill go on friday and check it out
    Oct 2001
    good luck ! and i 'll post some service manual pages about the antenna for you !
    MIKE
    Oct 2001
    here are the pages i found in the service manual ( thanx to paul )
    sorry for the big files !
    good luck ! and tell me what happens , i am interested in that matter too !
    MIKE
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    My power antenna only makes a humming sound (it doesn't work either)
    10/Honda/Ridgeline
    NJ
    that humming sound is the motor turning. but nothing happens because the platic rod that pushes and pulls ur antenna up and down usually gets snapped. the rasons are bad platic, bad manufacturing. or even unlubricated pwt antenna mast. The first thing i did when i got my car was to lube the car and every time after a car wash, i lubed it, esp during the summer and sometimes during winter. MY antenna works like new. Never gave me a problem of either getting stuck or snapping. yeah its a bitch to replace. u can go to a store like pep boys or something and get a trunk mounted (like the 4g) pwr antenna which is better to troubeshoot since u dont have to dig up under the pile of wires and dash crap. Also yea, u would be needing a longer antenna wire which is not much i hope.
    Oct 2001
    mine doesn't do a sound at all !
    MIKE
    Jokelahoma
    Im on a T3, so the file size doest matter
    Thanks dude, that helps alot
    Oct 2001
    good luck and let me know what happens !
    MIKE
    Mankato, Minnesota
    Ok, if I did put a new one on the trunk, is it possible to use the switch that I already have to control the on for the trunk? Wouldn't I just run the new wires to the switch and disconnect the old ones? Correct me if I'm wrong.
  1. another frickin' universal muffler question
    By nolliethebum in forum Performance
    Last Post: 07-10-2003, 05:43 PM
