Does anyone know if there is a difference between a Fuel injected 4 door instrument cluster and a Carburator 4 door instrument cluster?
Nothing like a SEI
Yes. Fuel injected one has a CEL and some had the PGMFI. Otherwise, I don't think there is a difference.
Is it worth buying the carb cluster with low miles. what is it that I need to do to convert it.
Nothing like a SEI
what why do you need a new cluster
what is a cel?
Are all the connections the same.
I just did a auto to 5 speed swap yesterday. Fingers hurts. I need a cluster for a 4 door manual.
I found one but it is from a carb car though.
Nothing like a SEI
Just swap the Temp/fuel gauge itself and keep the rest intact. It has to be from the same manufacturer tough (NS and Denso)
I need these parts!
CEL = check engine light
should be PnP as far as I know
i messed up the gauge cluster last time.
So the carb has the cel and the fi has the PGM-FI light. I am just hoping for a cluster that i can plug in and go. Why would I have to swap the fuel temp. That is the one that I messed up last time. I found a carb with 87xxx miles. I wanted it but I want a plug and play. what should I do? What should I buy.
Nothing like a SEI
found and bought 123,000 no more automatic crap. thanks guys
Nothing like a SEI
Fuel Injected models had a CEL and PGFMI light, well coupes had the PGMFI for sure. Carb'd models do not have any of those.
carb's 13" rims. fi 13" or 14" rims might notice what it cam off of. speedo will be off with different tires
i always thought it was in the dash that made the difference. in that case my speedo's been off a long time!
I need these parts!
carb clusters will make the VSS not work and there is no check engine light
so ...
DO NOT GET A CARB CLUSTER
