hello i need the hose diameter for the rubber hose that comes off the oil pan and goes to the air breather possably? i know its leaking oil at the moment and its on the rear of the oil pan thanks
actually could you tell me the name of the hose so i can find it on majestichonda.com or help me it would be much appreciated thanks
http://www.hondapartsdeals.com/hpa_p...php?vin=&Label[ProductID]=ACCORD&Label[YearID]=1988&Label[DoorID]=4&Label[GradeID]=LXI&Label[AreaID]=KA&Label[TransmissionID]=5MT&Label[SectionID]=ENGINE&Label[IllustrationGroupID]=BREATHER+TUBE+-+OIL+FILTER&ProductID=5&YearID=27&DoorID=4&GradeID =72&AreaID=2&TransmissionID=3&SectionID=1&Illustra tionGroupID=5600
I've been looking at that its the number 003 hose right?
You sure that's all that's leaking? My upper hose was leaking too along with the PCV valve. Good grief, the whole thing was a mess.
well there might be a oil pan leak to but im trying to narrow it down one by one, I bought a pcv not to long ago, Im gonna degrease the engine after i put on the new hose and see if there is any other leaks, its only my beater, got it for free put $50 into it to get it running and been working on it since
i was JUST about to post regarding the same thing!
so, oil does NOT run through this hose? i believe it is 7/8'' for diameter...every auto parts store i went to either had 3/4'' or 1''
88 accord lx-i..the new daily, 185k, 5 spd, 2dr
89 accord lx-i..sold
97 Z28..sold
gotcha
im just gonna go to a local scrapyard and see if i can find one rather than the dealer or something
97 Z28..sold
i cant find an auto parts store that carries the size i need, though...we'll see
97 Z28..sold
Have you changed the oil filter base gasket.
This is a notorious for leaking its a $5 gasket and takes about 30 minutes to change.
Phil
I just added worm clamps to it next to the factory type clamps. It was not an easy job.
grrr changed it and its still leaking from the back of the engine i think it might be the oil filter base gasket =/
