Page 1 of 5 12345 LastLast
Results 1 to 25 of 115
Thread: It's Toast
    Accord of the Year - 2008
    TWOLOUDNPROUD's Avatar
    May 2003
    Angry It's Toast
    About 15min's ago my wastgate failed and it hit 20+ psi and my headgasket went bye bye i have water in 1 and 2 and it blowing exhaust out between the head and the block.
    Re: It's Toast
    holy mother fucking shit!
    SEi User codyJDM's Avatar
    Apr 2008
    '88 civic wagon
    SoCal
    Re: It's Toast
    OT but I hope customs wastegate doesn't fail.. LOL.
    That sucks so bad man. Good luck and keep us posted I hope it isn't as bad as it sounds :-(
    Re: It's Toast
    well head gaskets can be replaced. Hope for nothing more then that.
    May 2003
    Re: It's Toast
    A18A or B20Accord I need a headgasket get me a price and PM me A.S.A.P.
    Dec 2003
    Millington, TN
    Re: It's Toast
    Sad to hear, so what are your plans now?
    Phil
    May 2003
    Re: It's Toast
    Quote Originally Posted by nswst8 View Post
    Fix it as fast as i can i have the time just need the part.
    Re: It's Toast
    :( NOOOO you have such bad luck :'(
    Re: It's Toast
    Noooooooooooooooooooooooooo!
    Re: It's Toast
    wow man....lol you have not so good luck...clean up the water and new head gasket and you should be good. Unless your rings are toast to 20psi is alot lol damn.
    Re: It's Toast
    FU@K
    that bites, exhaust out the crack.... dam
    sorry to hear that
    that other source you mentioned doenst have any more gasket sets? I thought this was going to be easy, I guess I need to get some ordered too.
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Re: It's Toast
    I have a headgasket I can sell you Tommy.........pm sent
    carotman's Avatar
    Montreal South Shore
    Re: It's Toast
    Ouch sucks.
    You can get gaskets fron this company if you want:
    http://bgautomotive.co.uk/
    That's what I'm using on my car. They're located in the UK and give fast shipping. You can always order 2 or 3 gaskets... just in case something goes wrong.
    The gasket you need is this part number CH8303
    I need these parts!
    Re: It's Toast
    if the block was o ring grooved it would have bent a rod or something? or would that have saved the gasket?
    edit: oops wrong motor NVM
    May 2003
    Re: It's Toast
    Quote Originally Posted by bullard123 View Post
    You have a PM
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Re: It's Toast
    too bad!
    what went wrong with the wastegate? the hose came off? or just a cheapo one?
    Link to my 3geez garage
    May 2003
    Re: It's Toast
    Quote Originally Posted by thegreatdane View Post
    too bad!
    the diaphragm popped a nice hole in it.
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Re: It's Toast
    Jesus, that sucks.
    Yay for headgaskets that act like fuses.
    What wastegate are you using?
    alex
    May 2003
    Re: It's Toast
    Jesus, that sucks.
    alex
    it better to pop a headgasket then a piston and it a Tial knock off but it worked sweet for about a year
    S.Glastonbury, CT
    Re: It's Toast
    Sorry to hear that....I tried to warn you about that knock off tial. Hopefully thats the only problem.
    SEi User
    Feb 2004
    Panama City, FL
    Re: It's Toast
    Well i hope its an easy fix. What are you running for fuel management. You should in vest in something with over boost protection. I'm running eCtune and have my over boost set at a pound of boost above what i want to run, If it hits it the ecu will cut ignition until the throttle is lifted.
    Pgm-fi conversion 4-16-05
    OBD1 11-25-06
    Turbo 2-26-07
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    Re: It's Toast
    what headgasket were you using that blew? just stock/oem?
    could also look at getting a copper gasket. they are a bitch to get installed 'properly' but should hold well once they are properly installed especially if you get some nice head studs/bolts. :)
    Re: It's Toast
    im a bit late in this thread but that sucks to hear u have to pull it apart again. Your car soends more time off the road than a rotary. If it says made in china dont buy it, Knockoff parts just suck, Ok for a while but then they will cause you fail
    suckssssss
    head gaskets over here cost $60NZ for the gasket
    Re: It's Toast
    man that sucks...hope it gets done quick..cuz we need an all cali meet
    May 2003
    Re: It's Toast
    Quote Originally Posted by RobT5580 View Post
    I been looking for a waste gate but i have not found what i want. And i hope the head gasket is the only problem to.
    Quote Originally Posted by EricW View Post
    Im using crome and it did cut off but it went from 8psi to 20+ just like that then pop and a shit load of white smoke.
    The head gasket i am using is AJUSA it better then the stock head gasket but not meant to do 20+psi.And i called GASKET WORKS USA to see about a copper head gasket and it going to set me back about $180 for it so if i blow another one i am going copper gasket. And i do have APR Head studs. Here some pic's of the ajusa head gasket.
  1. Car is Toast
    By DBMaster in forum Classic Honda Community Chat
    Last Post: 06-15-2012, 07:36 AM
  2. I think our poor old 3G is toast
    By oldsub86 in forum 3geez Accords
    Last Post: 07-30-2005, 08:56 PM
  3. My deck is toast!
    By snow_man_20 in forum Interior & Exterior Care
    Last Post: 02-11-2005, 12:38 AM
  4. Please help !Starter's toast in my 88 LXi
    By los in forum 3geez Accords
    Last Post: 01-06-2005, 06:43 AM
  5. Is my trans TOAST?!!!
    By microracer in forum 3geez Accords
    Last Post: 03-14-2003, 01:13 AM
