Page 14 of 22 FirstFirst ... 4101112131415161718 ... LastLast
Results 326 to 350 of 550
Thread: A18A's 1989 Accord CA Thread
  1. #326
    Re: A18A's 1989 Accord CA Thread
    this is what my window switch thing has looked like for the past year or so:
    so i took off the door panel:
    got a donor one:
    took its switch:
    old with the new:
    installed in the arm rest:
    arm rest reinstalled on the door panel:
    door panel reinstalled on the door:
    and win!
    plus a video of it in action http://www.youtube.com/watch?v=DNWVMgYRnEI
  2. #327
    oh thats bbeeaaaauuuuutiful
  3. #328
    You should ship me the old switch and armrest for free
    kbai!!
    hmm i dont understand whats going on is there any way you could be more detailed?
  5. #330
    SEi User ZackieDarko's Avatar
    this
    what is different?
  6. #331
    Well what I did was, after unlocking the car and openning the door, I put my key in the ignition and turned it to "ACC" and pressed play on my MP3 player so i could listen to music while i done the work. What I did was got a phillips screw driver & started removing all the screws in the drivers door panel, I had to remove one of the screw covers with a flat blade screw driver first though. After I got all the screws out, I carefully removed the speaker cover & door handle surround. Then I put a flat blade screw driver between the door panel and door, and moved it along the outside till it got close to the clips, then i pryed them apart. once that was completed, I lifted the door panel upwards from the door, once it was separated I unplugged the window switches plugs & the door panels light to seperate the door panel from the door completely.
    then from the DONOR door panel i undone the screws on the back holding the arm rest to the door panel, after that came off, i undone the 4 screws holding the window switch to the arm rest. the same was done to the grey door panel. After I was done removing the faulty switch from the grey arm rest, I installed the good switch into it, then reinstalled that into the grey door panel. then after that I installed the door panel back on the door, pretty much the reverse sequence of its removal. after the finishing touches of installing the door handle surround, speaker cover & screw cover, it was complete & i was good to go
  7. #332
    what kind of nut sack goes and welds this thing on backwards??
    anyways i spent most of the day removing just that exhaust because 1 nut that holds the downpipe to the manifold failed so bad that a smaller socket bashed over it wouldnt get it off, and i have limited tools, so i had to lower the cross member, remove the engine mounts & radiator fan & other misc items just so i could fit the grinder down there and get it off.. all that just cause of 1 nut gah.
    anyways old with new
    evidence of some leakage
    i stuck heaps of gasket sealer stuff on them all when i put it back together and now the car is QUIET yay!!! i think i may have to swap the muffler again though as something back there fails and keeps hitting something gr
  8. #333
    woops
  9. #334
    Jun 2009
    When pulling out the engine in the Accord the same thing happened with one of the nuts holding the exhaust to the manifold. Much time wasted..Finally got out the Dewalt and cut the exhaust since I was pulling the engine.
  10. #335
    i got these really mint pre facelift tail lights
    and i wanted to install them, but we all know that to do that properly i need the matching boot lid, unfortunately i don't have one, so i decided to see if there was a way i could make them fit. so i put them on the boot lid to see how they would look, just needed to make a couple holes bigger for them to fit and there we go
    but that lack of plate surrounding bothered me, so i got the old one which was cracked and looked ugly
    and shopped off the ends
    and stuck it on
    yay, now just needs a bit of bog or something, and some black paint. this should do the job good enough till i can get me a mint pre-facelift boot lid.
    i also swapped in some key-hole-less front door handles
  11. #336
    awesomeness
  12. #337
    indeed
  13. #338
    filled and painted black nao
  14. #339
    cumsicles (Y)
  15. #340
    Oct 2009
    Nice job
  16. #341
    i spent a lil while today cleaning up the engine bay some, swapped P/S hoses for one that was made for a b20a, just to be that little bit more factory looking, hosed the motor down (i wish i had a water blaster) and the engine bay of random fluids, painted p/s resivoir black (done that the other day actually) and some other little bits and pieces lol. looking betterer now, heres some photos
    and done
    im happy with the result
  17. #342
    hai
  18. #343
    took it for a wof today, figured id get in early, failed on:
    indicator bulbs hanging loose inside bumper (used them to add resistance as my orange bulbs didnt have enough)
    corner lights not flashing in sync with bumper lights (lol)
    LF lower ball joint
    igniter bolted over top of vin tag
    a hole under the right rear of the car
    all jacking points on the left side bent
    oh and the RF tyre apparently wasnt round lol
    lol how gay is that
  19. #344
    Remind me not to move to NZ kbai
    holy strict batman
  21. #346
    indeed, so far ive done the ball joint, indicators, swapped wheels, relocated vin tag, closed the open hole under the right rear, and hammered the jacking points straight. i'll go back tomorrow and hopefuly they let it pass without having to weld up anything heres a few pix
    straightened these as much as i could
  22. #347
    hahahhaha they didnt pick on my improperly mounted integra seats & seat belts lol!!!!!!!!!!!
  23. #348
    passed
  24. #349
    Mar 2008
    how on earth do bent jack mounting locations make a car unsafe to drive on public roads? thats pretty dumb.
  25. #350
    how does out of sync blinker bulbs make it unsafe? LOL nz is very strict (N)
  1. A18A's 1988 Accord 2.0Si
    Last Post: 12-13-2013, 03:32 PM
  2. A18A's 1989 Accord CA Thread
    Last Post: 03-24-2013, 12:43 AM
  3. Feeler thread: 1989 Honda Accord LX
    By russiankid in forum Classic Honda Community Chat
    Last Post: 03-16-2011, 07:10 PM
  4. November Accord of the Month - A18A
    Last Post: 11-05-2009, 11:55 AM
  5. 1986 Accord EF JDM A18A
    By Teratani in forum 3geez Accords
    Last Post: 05-23-2008, 10:36 PM
