Results 1 to 10 of 10
Thread: 1989 Honda Accord Fuel Pump removal.
    Jul 2008
    Hey guys, I just replaced my fuel filter and its not pumping gas, so i have looked and looked for how to remove this thing, and all I can come up with is its under the back seat, correct? Anyone done this before or have any info? Thanks!
    Re: 1989 Honda Accord Fuel Pump removal.
    you need to remvoe your boot carpet and spare wheel cover and the whole back seat to make it easyer, then you will see two caps there it will be under one of them, just a bunch of 10mm bolts to undo. the fuel sender will be on the right pump on the elft looking from the back of the car
    Jul 2008
    Yeah, i see them. Ok, so you think what it sounds like is the fuel pump or fuel sender?
    Was it pumping gas before you put the filter on it?
    The Main Relay controls the fuel pump and shuts it off for safety if the engine is not running.
    SEi User 86ccord's Avatar
    Middle Georgia USA
    hey go under the hood on the driver side pull the fuel filter line apart and have someone pump the accelerator pedal and see if fuel is coming out.. if not then it is the fuel pump..
    it happend to me.. lol
    one day I'll return.
    DX User kyaccord's Avatar
    Sep 2008
    im havin the same problem kinda i can get the pressure in the gas tank but nothing makes it to the fuel filter. what the hell is wrong with it? is it a fuel regulater or what?
    Jul 2008
    I recently replaced the fuel filter and the fuel pump. Problem was helped a little, but it was still there. I just ordered a brand new main fuel relay, and its working like a charm. I'd first go pick up a new filter, then a main relay, cuz more than likely your pump is good, just not being triggered on.
    5.25 Memphis Mclass fronts
    6x9 Memphis PR Rears
    Street Edge amp
    15' Memphis PR sub with ported box.
    Next, head work, new exhaust(2 1/4 inch) and cam.
    Pumping the gas doesn't turn the pump on.
    DX User griffonks's Avatar
    89 LX
    Parker, CO
    Hi
    Is your car aspirated or fuel injected? Carbureted accords have two filters, 1 at the tank and one at the firewall. Also 20 year old fuel and vacuum lines crumble, believe it or not. There are a bunch of rubber lines at the tank...... I replaced all of the rubber in my 89LX beater last year because it was cracking. You should hear the fuel pump power up when you turn the ignition on. If not check the wiring at the pump for live elec. If the pump is 'hot' pull the closest fuel connection to the tank, before the fuel filters or filter, and see if it passes fuel. good luck.
    Sep 2008
    its fuel injected. i cant hear the fuel pump kick on but if i prime it a couple of times then go open the gas cap its got some pressure behind it. i call me dad earlier and he called me a f**king idiot he so go get some damn gas its probably dont have enough in it to suck it up. its at 1/4 tank so im gonna try that and see what happens. im thinkin that the rubber hoses inside the tank are bad now that you mentioned it cause when i get about 1/4 tank its starts to sputter a little
  1. Replies: 3
    Last Post: 01-19-2007, 06:49 PM
  2. 1989 Accord – Weak Fuel Pump?
    By Swap_File in forum EFI Tech
    Last Post: 09-05-2006, 09:52 PM
