Results 1 to 9 of 9
Thread: 88 LXi slip ring
    LX User Strahan's Avatar
    Mar 2003
    York, PA
    88 LXi slip ring
    Is the car safely operable without it? I've been noticing an annoying squeak when I turn the steering wheel. I was going to spray some WD-40 in the crack between the wheel and the column, but figured I'd better remove it alltogether and use grease. Well, I'm glad I did because it turns out it wasn't friction between the wheel and column but rather internal to the slip ring. I'm going to go to the yard this week and pull one.
    Just wondering if I can operate the car safely w/o putting it back on. I was just gonna leave it all apart and bolt the wheel back on so I can drive it until then.
    Also, my cruise is not working. I'm hoping that maybe replacing this will make it happy again, here's to wishful thinking
    Ken
    Re: 88 LXi slip ring
    mine will do that ever since I swapped out combo switch.. but only if the ambient temp is over like 85 degrees.
    that is for the horn and cruise switches to work , the slip ring
    Vanilla Sky's Avatar
    1999 Penalty Box
    The slop ring is most likely the cause of the CC not working as well. You can take your ring apart and most likely fix it.
    That ring does turn the turn signals off after a turn, so you're going to have to remember to turn your indicators off after a turn.
    Mar 2003
    York, PA
    I ended up just saying screw it and went without heh. Alas, my CC is still out of commission but at least I've removed one possible variable now. My steering wheel is nice and quiet now when I turn, hehe, and as an added bonus the donor car I was pulling the slip ring from was an 86 hatch and it didn't have my style steering wheel. Instead of 4 small horn buttons you just pressed the whole face down. I like that alot better, so for another $30 I took the wheel. I also took the turn signal because I noticed when I pulled the slip ring that mine is cracked, however the 86 stalk apparently isn't compatible. The mounts on the side opposite the spring/ball were diff.
    Ah well. Anyone need an 86 turn signal switch? Hehe.
    Ken
    Quote Originally Posted by Strahan View Post
    This guy does.
    LX User rfiks's Avatar
    Sep 2008
    88 accord hb dx
    el paso
    hmm...
    2ndGenGuy
    Guest
    Quote Originally Posted by rfiks View Post
    hmm...
    What the fuck? Stop post whoring.
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Thank you 2ndGenGuy.
    Andrew.
    SEi User codyJDM's Avatar
    Apr 2008
    '88 civic wagon
    SoCal
    hmm...
    You're not very smart are you?
  1. Accord SE-I Slip Ring
    By tdsh354 in forum Wanted
    Last Post: 07-19-2012, 12:13 PM
  2. WTB: Steering wheel slip ring
    By Nafs Asdf in forum Wanted
    Last Post: 04-30-2011, 10:35 PM
  3. horn slip ring
    By lostforawhile in forum Wanted
    Last Post: 02-04-2010, 09:09 PM
  4. 2nd gear tire slip
    By HondaBoy in forum Classic Honda Community Chat
    Last Post: 02-02-2005, 06:31 PM
  5. 1/4 time slip!!!
    By Jebus in forum Performance
    Last Post: 04-30-2003, 09:53 AM
