Page 2 of 2 FirstFirst 12
Results 26 to 47 of 47
Thread: Car NOT STARTING
    LX User Timaculent's Avatar
    Apr 2004
    1989 Honda Accord SEI (SOLD)
    Miami Florida
    Re: Car NOT STARTING
    it cant be tthat the belt is broken because i am getting spark to the spark plugs. it is more so the timing belt might have jumped timing.
    Nothing like a SEI
    I notice in this thread https://www.3geez.com/forum/showthread.php?t=66426 that you performed some creative re-wiring around the TW sensor. I don't suppose that got reversed, did it? Perhaps there is a broken wire in that vicinity now? What you describe sure sounds like an electrical problem to me, or possibly a clogged fuel filter.
    To check your belt, just put the crank at TDC and remove your valve cover. If the cam is at TDC too, you're good.
    Oh, and don't drive like an idiot. Be goooood to your 3gee!
    Apr 2004
    Miami Florida
    I just pulled out the pins out of the clip and connected them directly.
    It started fine that morning and drove fine.sense its a sensor and it detects heat does it matter how the wires are in?
    I dont think I reversed it. I am getting fuel out of my fuel pressure regulator.
    I couldnt touch the car today as I have to work all day. I am hoping and leaning towards the timing belt. i hope to do this tonight or tomorrow.
    Nothing like a SEI
    Apr 2004
    Miami Florida
    Oh, and don't drive like an idiot. Be goooood to your 3gee![/QUOTE]
    Me no idiot just excited about having new motor, stick and pacesetter header.
    Nothing like a SEI
    Apr 2004
    Miami Florida
    Compression good
    The car Started. What is that sensor on the thermostat housing that is black. when the wire are connected it starts but when they are seperated it tries and tries to start?
    What is this sensor?
    Nothing like a SEI
    Dec 2003
    Millington, TN
    One is the TW sensor the other is the Thermo switch
    Phil
    Apr 2004
    Miami Florida
    The tw is the smaller one. why does the other one not allow the car to start if it is not connected.
    Nothing like a SEI
  8. #33
    Apr 2004
    Miami Florida
    now it will start when i join the sensor wires together and then it wont when i disconnect them. Anyone have an idea? This is weird. Additionally I got a new sensor and the light is still coming on. Man what the heck do I do now. The other thing is now the fan comes on after I turn the car off and stays on I read somewhere that it was the IACV that causes this? Any advice. Man why is it always something.
    Nothing like a SEI
  9. #34
    Fan is normal. What's the code?
  10. #35
    Apr 2004
    Miami Florida
    6
    Nothing like a SEI
  11. #36
    Nafs Asdf's Avatar
    Feb 2008
    Finland
    Are you sure you aren't confusing the TW and temp gauge sensor? Pulling the temp gauge sensor plug wouldn't do anything but prevent the gauge from working. While messing with the TW sensor might do a bunch of things.
  12. #37
    Apr 2004
    Miami Florida
    Quote Originally Posted by Naf's Asdf View Post
    I might be. So the TW sensor is the smaller one that is closer to the head correct. Well maybe that is it. and I am wondering about my pressure. because it is spitting water out of the bleeder valve but is it possible that air is still in there?
    Nothing like a SEI
  13. #38
    Dec 2003
    Millington, TN
    If the bleeber is spitting/bubbling you have air in the system.
    Engine off. Set heater to max heat(this opens the heater core valve) Drain half the radiator, open bleeder refill radiator, when fluid starts to come out the bleeder close it off. Start engine let fans come at least twice, refill radiator as needed. And your done.
    Phil
  14. #39
    Apr 2004
    Miami Florida
    also i do not have the harnesses that plug into the sensor. does it matter which way they are plugged in?
    Nothing like a SEI
  15. #40
    Dec 2003
    Millington, TN
    Okay, you need to give alitte more information than you have thus far. We know that you swapped in a engine A20a1, A20a3 what type car do you have. You need a manual.
    Phil
  16. #41
    Apr 2004
    Miami Florida
    Quote Originally Posted by nswst8 View Post
    I have a A20a3 SEI I have the Haynes but it is not detailed on this topic.
    Nothing like a SEI
  17. #42
    Dec 2003
    Millington, TN
    So you have a SEI accord and you replaced a A20a3 with a A20a3. I don't understand your harness question.
    Phil
  18. #43
    Apr 2004
    Miami Florida
    Yes and sei
    I have the wires pulled out of the clips that go into the sensor. i plugged them in with out the plastic piece. One is black and the other is another color. does it matter with side they are plugged into.
    Nothing like a SEI
  19. #44
    Dec 2003
    Millington, TN
    I don't believe that it matters, I don't think the sensor is designed for polarity.
    I you need another plastic connector snag one from the junkyard.
    Phil
  20. #45
    Apr 2004
    Miami Florida
    I will I am trying to get up there today.
    Nothing like a SEI
  21. #46
    Apr 2004
    Miami Florida
    I Got It And Quite A Few Other Things.
    Man There Were Six 89 Accords Up There.
    3lxi
    2 Lx And One Dx
    So Many Parts To Choose From So Little Time.
    I Have Crimpted The Wires To A Butt Connector And Just Need To Install It Tomorrow. I Cant Wait. My Next Project Will Be To Get My Ac Going. Cause Miami Is Too Hot.
    Nothing like a SEI
  22. #47
    Apr 2004
    Miami Florida
    SUCESS EVERYTHING IS WORKING AGAIN. NOT ONE ERROR LIGHT ON IN THE DASH
    This is weird because I have one of the oxygen sensors disconnected.
    Ok now to get me ac working.
    Nothing like a SEI
  1. Not starting
    By BigEA20 in forum 3geez Accords
    Last Post: 01-18-2013, 12:24 AM
  2. Car not always starting
    By 87SIA20A3T in forum 3geez Accords
    Last Post: 09-23-2008, 03:27 PM
  3. help... car not starting.
    Last Post: 01-22-2008, 06:04 PM
  4. Need help starting car
    By dmitch31 in forum 3geez Accords
    Last Post: 06-16-2007, 10:43 AM
  5. Starting out
    By Arseassin in forum Classic Honda Community Chat
    Last Post: 01-14-2005, 02:17 PM
