I would not tell anyone to do anything I would not do myself.
Yes, I did what I told you on my car. With my car dead cold, I disconnected EGR valve sensor, turned it on and started driving. No codes until engine got warm, then code 12. Turn engine off, then back on, and started driving; as the engine was already warm, the dashboard light came on almost immediately.
Later that day I did another test but this time with what I exactly told you (#16 hose disconnected). ENgine cold, I drove for a mile or so with no dashboard light but once it was warm... dashboard light on and code 12 on the ECU led.
So, whatever problem flagged a code 12 when you first posted seems gone now.
Your ECU does not flag a code when everything is connected because it is using your EGR system. I had thought that if the TW sensor was off range somehow it might not let ECU know that engine was warm enough for EGR to come on... well, I was wrong although the theory was right; you can drive the car while cold and no dasboard light (or computer code) would show up until engine is warm and attempts to use EGR system.
Now we have a failure that is EGR-related but your system -for all evidence we have- works. The only reason left is EGR passages partially or totally clogged. It may be that your EGR valve is clogged with carbon, or the individual runners to each cylinder are partially obstructed. Far less likely, the pipe bringing exhaust gases from the exhaust manifold to the EGR valve may be clogged. IN any case, even if the system works, if there is an obstruction somewhere that prevents exhaust gas to reach the cylinders you'll have a NOx failure in an emissions test.
You may try removing the EGR valve and looking for carbon deposits if you have not done so. With the valve out you may try running the car to see if exhaust gases get to the valve; you'll hear noises if the passage from the exhaust manifold is unobstructed. Oh, the f... nuts on the EGR valve are f... hard to get out; make sure you get a hexagonal socket of the right size or you may not be able to get them out
Try getting the document below; although it applies to Accords 1990 and later they have the same delivery system of individual EGR passages and suffer the same problems; what refers to the 1990 model in that document seems to square right with 3Gs.
http://home.comcast.net/~em-engineering/T2T013.pdf
Sorry for the delay: I was out of town last weekend and I am nuts w/school stuff...
