Results 1 to 25 of 34
Thread: The Joy's of a Boosted B20a
    Accord of the Year - 2008
    TWOLOUDNPROUD's Avatar
    May 2003
    I did a compression test to day
    Cyl#1
    Cold 90psi
    Hot 90psi
    wet 95psi
    Cyl#2
    cold 169psi
    Hot 175psi
    Cyl#3
    cold 165psi
    Hot 185psi
    Cyl#4
    cold 190psi
    Hot 185psi
    Do i need to say any more.Time for new pistons.
    Re: The Joy's of a Boosted B20a
    I'm beginning to believe that you enjoy working on this car more than driving it...
    Just kidding. Good luck with the rebuild and hope you get it running quickly.
    do i dare say it sounds less reliable than a rotary? :O
    I assume you checked those cams you just put in .
    It's hell when it's well, but seems to be calling in sick a lot.. lol
    just messing with ya..
    edit, I just remembered, didnt that one time the gasket blew out the number one side, I have to go back and look at those pictures. I wonder if the block deck across the cylinders should be checked too.
    S.Glastonbury, CT
    I think your over doing the stock bottom end. I know what your going through although my mishaps were much more expensive i did loose hope after awhile. But needless to say im invested to far to stop so im giving it another go. If i could go back before i busted the $10k limit i would get decent rods, forged pistons, ARP studs and go from there. I went overboard with my valve train and a bunch of other stuff that just blew my budget.
    Right now im working on getting a OEM honda head gasket, then i need pistons, EMS, turbo, and finish my new manifold and i should have mine running. As fun as the boost is it definately brought on a rath of stress. But im addicted to turbo's so we shall see what happens in 2009.
    Wish you luck!
    May 2003
    When the head gasket blow it was at 6000rpms and the water went in the cyl that more likely what killed the piston. I should have pulled out the pistons and checked them before i put the head back on.
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    did you do a leak down test? doesnt necessarily have to be the piston rings.
    Link to my 3geez garage
    May 2003
    Quote Originally Posted by RobT5580 View Post
    Wish you luck!
    I started on my other B20a but it slow going money is tight right now but i am have fun with what i have i will have new piston and rings by this weekend so it will be back running next week.
    May 2003
    Quote Originally Posted by thegreatdane View Post
    it's blowing oil out the VC.
    Quote Originally Posted by TWOLOUDNPROUD View Post
    ahhhh ok
    S.Glastonbury, CT
    Cool i guess its good to experiment on this one then so you know what your doing when your boosting a more expensive build. If it makes you feel better i think im on build #4 my first one was my fault and i washed out the cylinders, second time i think was a boost spike, and the last time race engineering sold me rings that would not hold up to boost. The last one blew oil because of that so i beat it knowing it was coming apart.
    Jan 2003
    Denmark/Europe
    wait. .........it's not supposed to do that???
    :D
    So what pistons you getting?
    May 2003
    Stock PK2-A 9:5:1 for right now i had PK2-B 10:5:1 maybe the step down in compression will help it last a little longer untel i get my other B20a done.
    i like totally missed this thread. Im sure it will run better with even compression lol. i think my b20a has a burned valve as i get 190psi on 2 3 and 4 but 125psi on cyl 1
    May 2003
    Check your valve lash it may be to tight keeping the valve open just a hair.
    i done the tappets a few days ago and it didnt fix it aye
    May 2003
    This sucks ass i was going my storage today guess what i found the pistons and rods from my other b20a they are PH3Z witch are the same as the PK2B pistons.Now i bought new pistons for no reason i wasted my money for nothing Dam DAM DAM.
    they can be spares :)
    May 2003
    I don't know if this will help but i did it anyways :6
    Before
    cleaned
    After ( polished )
    Shiny!
    do that to my truck please :wave:
    May 2003
    Thank You
    May 2003
    Here #1 piston now you can see why it was only 90psi
    indeed you can.
    Jan 2003
    Denmark/Europe
    sheesh.. How does the cylinder look?
    That polished piston looks sweet! now you need a window in your engine so you can see the shiny pistons :p
    May 2003
  1. has anyone boosted a b20?
    By 3geeandEF in forum Forced Induction
    Last Post: 09-04-2007, 02:26 AM
  2. Boosted guys... What plugs are you running?
    By AccordEpicenter in forum Forced Induction
    Last Post: 03-02-2005, 03:47 PM
  3. I have 2 Accords, 1 boosted, 1 stock.
    By According2Me in forum Newbie Introductions
    Last Post: 12-16-2004, 04:21 PM
