Page 5 of 5 FirstFirst 12345
Results 101 to 108 of 108
Thread: Lazy man's distributor overhaul (TEC distributor)
  1. #101
    Mar 2015
    1989 Accord EXi
    Calgary, AB
    Re: Lazy man's distributor overhaul (TEC distributor)
    Do you have a link to a good replacement source for the TEC distributor? The link on the March28 post seems different than my dizzy.
    I've seen this one, but seems pretty expensive to me:
    86 87 88 89 Honda Accord 2 0 New Tec Distributor TD01N | eBay
    Thanks!
  2. #102
  3. #103
    Mar 2015
    1989 Accord EXi
    Calgary, AB
    Thanks! $80 cheaper!
    I decided to do a re-condition.
    Details here: https://www.3geez.com/forum/efi-tech/...ml#post1172158
    But next time I have dizzy issues I'll be ordering this one - assuming it doesnt disappear.
  4. #104
    Completely revised and updated.
  5. #105
    Dec 2013
    1989 Honda Accord Lxi 2 Door Coupe; 1989 Prelude 2.0si
    Seattle, Wa
    I havent seen this addressed here in this thread, but some TEC Dizzies have the plastic vacuum advance like shown on page 1, and are attached via the infamous C clip. Others have the metal vacuum advance and it has a screw that attaches it. I have one of each, where the metal vacuum one has a shot TDC sensor and the plastic vacuum cover snaps broke off and its held in place with wire ties & super glue.
    $64,000 question, can I morph the metal vacuum advance onto the presently working "plastic" TEC dizzy and get the best of both worlds, a working TDC sensor AND a solid non breakable metal vacuum advance??
    Thanks!
  6. #106
    That's a great question. You have the two. Give it a shot and let us know.
  7. #107
    I just want to add, removing the ring that holds the pin in the sprocket in place and removing the 3 screws under the advance mechanism easily removes the shaft and dorman kit #917-136 is the shaft seal
  8. #108
    That is valuable info indeed! Thank you!
  1. distributor
    By igarut5410 in forum Wanted
    Last Post: 06-13-2009, 10:49 AM
  2. Distributor Overhaul
    Last Post: 04-22-2008, 06:33 PM
  3. WTB: Distributor
    By qh187 in forum Trading Post
    Last Post: 12-18-2003, 07:38 PM
  4. Replies: 3
    Last Post: 09-06-2003, 01:03 PM
  5. Where to buy new distributor?
    By RL89LXi in forum 3geez Accords
    Last Post: 06-04-2002, 07:35 AM
