Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
Thread: Alll tire Gurus i need some input.
    Re: Alll tire Gurus i need some input.
    Quote Originally Posted by jpetrovic View Post
    well i get that now.. but i was wondering about the 5mm offset the motegi rims are lacking, can somone explain the Offset rules again. i a bit famillier with them but need more info.
    http://www.discounttire.com/dtcs/infoWheelOffsets.dos
    The offset of a wheel is what locates the tire and wheel assembly in relation to the suspension. More specifically, it is the measured distance between the hub mounting surface and the center line of the rim. Below is an explanation of the various types of offsets which are pictured in the above graphic.
    Positive Offset
    A positive offset occurs when the hub mounting surface is on the street side (the side you see) of the center line of the rim. Most factory rims will have this type of offset.
    Zero Offset
    When the hub mounting surface is centered within the rim, it is known as a zero offset.
    Negative Offset
    If the hub mounting surface is on the brake side of the center line of the rim, it is considered a negative offset or "deep dish".
    LX User evil88accordLX's Avatar
    Jul 2007
    gold 88 accord lx
    NWA (not the rap group)
    ^^^ exactly right. if the motegi's are the same width as your current wheels, the 5mm shouldnt be a problem. if the motegi is wider, the distance between the center of the wheel and the suspension side will be greater, and thats when you will have problems. that said, if you like the wheels and must have them, you can always get spacers.
    LX User jpetrovic's Avatar
    Mar 2007
    1988 Accord Lx-i
    Plano, Texas
    ahhh Okay, thanks for the info guys
  1. leds plz help me led gurus
    By b20a86lude in forum 3geez Accords
    Last Post: 10-04-2009, 07:21 PM
  2. Need Help, Electrical Gurus
    By 2drSE-i in forum Interior & Exterior Care
    Last Post: 01-21-2008, 03:28 PM
  3. Engine Gurus....I need your help!
    By tulowtugo in forum 3geez Accords
    Last Post: 07-29-2006, 12:39 PM
  4. tire size gurus, need to know ASAP
    By 2old_honda in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-06-2005, 10:48 AM
  5. Car audio gurus: HELP!
    By Raduque in forum Interior & Exterior Care
    Last Post: 06-23-2004, 01:49 PM
