Results 1 to 24 of 24
Thread: Is There A Cheaper Fuel Pump Out There?
    DX User kyaccord's Avatar
    Sep 2008
    i just took a swift kick in the nuts my fuel pumps out. i took it out of the tank where i could hear it kick on and nothing happened. so my question is.....is there any place that i can go to or another car fuel pump i can put on my car that isent like $10000??? the cheapest one i found is $149 i just need one to go in the car for now cause im tryin to sell it and buy another 89 ive been wanting. my car is a 89 lxi fuel injected 5 speed a20a3 if that helps. thank you so much
    Millington, TN
    Re: Is There A Cheaper Fuel Pump Out There?
    Pull one from a junkyard, or go to ebay.
    http://cgi.ebay.com/ebaymotors/FUEL-...spagenameZWDVW
    Phil
    www.rockauto.com
    AIRTEX Part # E8023 More Info {In Tank Electric Fuel Pump}
    $118.79
    $80 bucks at Autozone. Has been a year since I replaced mine and its fine.
    $80 Bucks At Autozone. Has Been A Year Since I Replaced Mine And Its Fine.
    Different Pump Homie
    If you're selling it, definitely get a junkyard unit. Just don't let it kick you in the nuts again, though. K?
    Didn't realize he had EFI. Sucks for you guys then.
    ^hahahhaa. yeah second hand ones are always the best
    Sep 2008
    to the junk yard i go!!
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    i thought the lower rate walboro was like $80 new.... imma look that up now
    Sep 2008
    ok so i to the fuel pump off and tested it on my battery and it works fine. i put it back on and left it out of the tank and its not working now. what in the worlds going on????
    sounds like main relay to me lol or just check the lines all the way back lol
    Sep 2008
    yeah its just wierd to me that its not wanting to pump when its hooked up but does when its off the car hooked to the battery. wheres the relay at?
    Sep 2008
    would that just work the fuel system?
    sounds like a voltage drop from a poor ground or a so so relay.
    I know some people used a gm fuel pump , not sure exactly if any fabracation is involved hanging it. It would posslbly last enough to get rid of the car but ideally you would use a FPR
    ^hahahhaa. yeah hand ones are always the best
    fixed it
    bawww hahaa haaha
    Sep 2008
    you think i could bypass the relay? and just give a continues curcuit?
    NO you are playing with fire, there is a reason it runs on a relay. NBD, they are like a cpl bucks at the JY.
    YOu dont want to sell the car to somebody and it burns up the following day
    you should be able to just bypass the relay by putting a wire between the yellow wire & black/yellow wire on the main relay plug
    Sep 2008
    i by passed it with a toggle switch just to see if it would run. im getting fuel to the engine now. im gonna see if i can get it running and just go to the junk yard and get one.
    LX User VIPER1988's Avatar
    Sep 2008
    New Market, TN
    http://www.autozone.com/selectedZip,.../selectZip.htm
    drivers side, under dash, above fuse panel
    pain in the a$$ to get to
    Oct 2008
    1987 Honda Accord DX
    Temple City, CA
    Quote Originally Posted by kyaccord View Post
    i By Passed It With A Toggle Switch Just To See If It Would Run. Im Getting Fuel To The Engine Now. Im Gonna See If I Can Get It Running And Just Go To The Junk Yard And Get One.
    Check The Fuse Before Anything, I Had Same Issue. Changed The #1 Fuse (fuel Pump/starter) 15a. Everything Was Good To Go After. I Have An 87 Dx.
    Sep 2008
    i looked at it and were it connects its silver instead of gold but it looks like its still connected
    20 post on a main relay problem. Common guys where better then this
  1. Fuel Assembly , Pump , & Fuel System Location
    Last Post: 05-10-2016, 01:27 AM
  2. Fuel Filter? Fuel pump?
    By Bass Man in forum 3geez Accords
    Last Post: 05-19-2008, 03:38 AM
  3. Fuel Pump Help
    By buttaz1 in forum 3geez Accords
    Last Post: 05-27-2007, 05:11 PM
  4. Replies: 2
    Last Post: 12-15-2006, 07:25 AM
  5. fuel pump?
    By Brentm in forum 3geez Accords
    Last Post: 02-02-2005, 11:05 PM
