Results 1 to 25 of 26
Thread: Anybody using Pledge furniture polish?
    When I got my car painted, the guy at the shop turned me on to Pledge furniture polish for conditioning and preserving the plastic and vinyl on my car. Just wondering if anyone is using Pledge and how it works over the long haul. I need to keep my stuff from aging in the Fresno sun, so any thoughts are appreciated.
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    Re: Anybody using Pledge furniture polish?
    I don't see how it would hurt anything. I use pledge to polish my guitar, and haven't screwed up the finish on it at all.
    2ndGenGuy
    Guest
    It's just kind of a wax in an aerosol can isn't it? The only thing that might worry me would be the lemony scent. But it doesn't ruin the super soft and porous wood that I spray it on. I'm sure it would be fine.
    i've heard this from the hot rod guys too, armor all will destroy your plastic.
    You need to know the base in the product you use on vinyl and leather that is exposed to UV light.
    If alcohol, or certain solvent base oils like mineral spirits are used it could soften up the material too much and then the result is when it dries out good again from UV it will split and expand, then contract when it cools.
    Some of the plastics in these cars is a little different than US models as well. An example of that on my car is the steering wheel slip ring will squeal like pig as soon as ambient temps reach around 84 degrees F. My throttle and TV cable housings also change at higher temps, I can have them set just perfect at 75 F then when there is 30 degree change either side of that the adjustments gradually change.
    On the Armor All, I usually cut it with water, and it works the same way with less penetration. Almost 50-50
    Nov 2000
    I use a protectant from Griot's Garage that leaves no residue. It is low gloss, also. I find glossy dashes distracting. If I had a newer car I wold only clean things with a damp microfiber towel because newer plastics usually do not have the thin vinyl over foam padding like ours. They tend to be solid materials. At a classic car show a long time ago someone told me that once you start using products like Armor-All your car becomes an "addict." Supposedly the silicone or chemicals in the protectant penetrate the plastic, solubilize the plasticizers, and cause them to evaporate as the protectant evaporates. So, if you don't keep using it the plastic will dry out. I can't really confirm or deny that. With the products I use I only apply them about twice a year and my dash still looks new.
    Honestly, the best protection for your interior is a UV blocking tint film and a windshield screen that you put up on hot sunny days.
    This is really good stuff, though.
    http://www.griotsgarage.com/product/...2C+8+ounces.do
    There is also a very plausible description about why most "protectants" are not good for plastics.
    At a classic car show a long time ago someone told me that once you start using products like Armor-All your car becomes an "addict." Supposedly the silicone or chemicals in the protectant penetrate the plastic, solubilize the plasticizers, and cause them to evaporate as the protectant evaporates. So, if you don't keep using it the plastic will dry out. Honestly, the best protection for your interior is a UV blocking tint film and a windshield screen that you put up on hot sunny days.
    Pretty much what I was saying, just different words
    Nov 2000
    That's true. Just give me something that can be stated in three words and I can turn it into an essay!
    LX User LxAcc510's Avatar
    May 2008
    1989 Honda Accord LX
    Where they say Hella, CA
    iron my shirt.
    I've used it years ago on my Olds Cutlass, but I used it on the paint
    Nov 2000
    Quote Originally Posted by LxAcc510 View Post
    iron my shirt.
    Do you prefer no starch, light starch, or heavy starch? On hangers or folded?
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    ive always used it on all my cars, and works wonders. peace.
    -Gio
    My E85 Turbo Build
    5280FEST
    Has it ever made your tires crack like Armor All does?
    Nov 2000
    If you are not a big fan of the "greasy tire" look you can just use Westley's Bleche-White. I buy it at AZ now, but Wal Mart may have it. It has been around since the days of fat white walls. It cleans the black rubber like new every time. Since it does not build up like the tire spray products your tires won't look like ass the first time you go through some puddles.
    I spray it on right after hosing down the car then scrub a little with a tire brush and rinse it off.
    That might work. It seems like everything I use makes my tires crack.
    LX User VIPER1988's Avatar
    Sep 2008
    New Market, TN
    i have always used stp son of a gun on all rubber plastic and vinyl. never had any problems with cracking or anything
    Quote Originally Posted by VIPER1988 View Post
    Well, it's either the protectant or all the drifting...
    Sep 2008
    New Market, TN
    drifting will definitely do it
    at least you have fun doing it though
    A Mile High.
    Wink Re: Anybody using Pledge furniture polish?
    I've never used on my tires before actually.. never really use anything on my tires unless im going to a meet or some kind of car show, ill just put some armor all on a rag and rub it on the tires lightly... never had a problem with them cracking..
    -Gio
    My E85 Turbo Build
    5280FEST
    Bringing back this thread. I've used the Pledge for a few months now and my overwhelming reaction is: meh. It's okay. It doesn't really condition the vinyl. It puts a nice low-key sheen, but over time, you can see the vinyl drying out/getting lighter beneath. It doesn't make the vinyl any more supple or any newer looking.
    Pledge is probably better than Armor All, but Zymol remains the best conditioner I've found. It's really expensive (made from lemon seed oil and coconut oil and pixie dust and unicorn spittle), but when you get done the vinyl pops. Everything of theirs that I've used pops when you're done. I won't touch anything but Zymol to the leather in my Bimmer. It's awesome. I was hoping for something cheaper, but no luck so far.
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    hmmm...ill have to look into this stuff for the TL seats..
    SEi User 86ccord's Avatar
    Middle Georgia USA
    i found some new tire shine stuff, it works really well IMO.. its called No Touch Extreme Shine.. and oh boy does it shine!! i like it.
    one day I'll return.
    i use the armor all wipes on the dash and all plastic and they rock.. the interior still looks good to me
    SEi User codyJDM's Avatar
    Apr 2008
    '88 civic wagon
    SoCal
    x2, not a crack in my interior and I use armor all fairly often. Used to use it religiously in my GSR which had leather stuff everywhere and never had a problem.
  1. port and polish
    By sinisterfuzzy in forum Performance
    Last Post: 04-21-2006, 07:36 PM
  2. Plastic Polish?
    By speedpenguin in forum Interior & Exterior Care
    Last Post: 04-15-2006, 11:45 AM
  3. Port and Polish??
    By w00tw00t111 in forum Performance
    Last Post: 04-03-2005, 08:48 PM
  4. Port and Polish
    By mag_pbg in forum Performance
    Last Post: 05-17-2004, 09:03 AM
  5. Port and Polish?
    By myaccord7 in forum Performance
    Last Post: 02-25-2003, 09:24 PM
