Results 1 to 11 of 11
Thread: Building a new engine (for boosting it later... again)
    DX User lui0046's Avatar
    Feb 2009
    1988 Accord LXI // 450cc blue top injectors // MSD BTM 5462 // SAFC
    Hey guys,
    I`am trying to get a new engine built, well actually, I`m working on having my car rebuilt. The paint is pretty damaged and the engine is not doing very well. I´ve been hearing a weird sound on the engine and I believe the gearbox is severily damaged too. Anyways, I would like some advise on getting my new engine build, cause I´m planning to boost it, again, later. I`ve read a lot about forged pistons, flywheels, connecting rods and all of that.
    My questions for now are
    1) Does anybody have the spreadsheet for a forged pistons order? I would like to keep eveything almost the same as the A20 (compression rate, piston size, etc)
    2) Are the b18c connecting rods the same size as the ones for the A20? I´ve read in the forums they are, just wanted to confirm.
    3) Which one is better? Aasco or clutchnet flywheel?
    4) The goal is to reach 200hp with just the BTM and the SAFC. Will that be possible? Or would you guys recommend getting a civic OBD1 chipped if planning to go around 10-15 psi?
    Thanks
    Re: Building a new engine (for boosting it later... again)
    Ill have to see if i can find some order info for my diamond pistons, they are stock profile for the most part, except they are bigger bore and smaller skirted i believe and the wrist pin size, but the compression and pin heights dont change, plus Ron at diamond is an awesome guy.
    No B18C rods dont fit. Youll need B18A/B rods... B18A/B rods are the same in every aspect to stock A20 rods except for wrist pin diameter
    im not really sure what the differences are with the flywheels, i have an aasco unit and i was told they are uber hard to come by these days.
    200hp with a btm and safc is doable but your better off going obd1 because after you buy and install/fuck around with the btm and safc you could have had the much greater flexibility of the obd1, ESP if your planning on going for higher boost (over 10-11 psi) i would highly highly reccomend the obd1. Dont forget to upgrade injectors and fuel pump as well
    Feb 2009
    Thanks man. That's what I needed. If you could find the order for your pistons that'll be great.
    So B18A/B rods huh? I believe I could look for them in some places around here and once I get them, I'll base the wrist pins on what they have.
    I currently have a btm and a safc, disconnected, since the turbo got damaged and got to take it off.
    As for the flywheel, I'll see what I can get, assco or clutchnet, but either one should do just fine.
    I was planning going OBD1 once the engine has been rebuilt so I could achieve more than 10psi.
    I got a walbro 255lph fuel pump and DSM 450cc blue top injectors, and I agree with you that I'll probably have to get some 660cc ones if planning to go over 10psi.
    The main goal is to get 10psi with the new setup. Then move to OBD1 and see what happens after that
    Thanks again
    660s are good to like 350-400whp at least so youll have plenty. Ill have to check on the order numbers though.
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Good info guys.
    So do you NOT need the BTM if you go obd1/chipped?
    Andrew.
    Good info guys.
    correct
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Damn, guess I'll be selling that then.
    Andrew.
    Dec 2009
    St. Louis, MO
    I'm stupid and curious on learning, but what does BTM and SAFC stand for?
    BTM=Boost Timing Modular(something like that) it just retards timing a set degree per psi of boost.
    SAFC=Air Fuel Controller, its a simple and extremely basic way to control the fuel going into ur motor.
    both are piggyback computers, and by the time you bought and installed them, youd be way better off going obd1. I started off with them and now im obd1.
    LX User gtmst3's Avatar
    Jul 2008
    1986 honda accord LX
    Waterbury
    im in the same boat im going to be doind an engine rebuild and possibly turboing it later i just want a daily driver with a little more pep. i was wondering if you guys had any suggestions as for engine internal components and i dont want to go crazy. i was looking at the eagle h connecting rods and dont want/ or think i need to spend 100$ a rod. so like i said just looking for some advice on a parts list. P.S. i plan on getting a b18/16 intake mani and portmatching it to the head along with a port and polish and slightly oversized pistons. i wanted to try to keep it to like 500$ for parts
  1. building an engine
    By gtmst3 in forum Restoration & Custom Fabrication
    Last Post: 06-30-2010, 02:30 AM
  2. Boosting Compression
    By mag_pbg in forum Forced Induction
    Last Post: 02-17-2004, 07:34 AM
  3. Boosting Compression
    By mag_pbg in forum Performance
  4. Boosting a B18
    By Elijah in forum Performance
    Last Post: 06-11-2003, 12:10 PM
  5. Boosting B18 ?
    By whiteboy in forum General Engine Swaps
    Last Post: 01-28-2003, 08:39 PM
