yes sir. Same as 89t setup. any b18 a/b 83mm pistons and any b18 a/b rods
83mm
stock. BUt if you want to put b series you need to get 83mm pistons then have the block bored to 83mm
so you would have to bore it out .30 mm from the stock 82.7mm
I just watch the video of u guys dyno'n .Very cool . . .
gOT MY MOOOTA today. thing is dirty but minty fresh. I got to swap all my parts over then obd1 the thing to not blow it up this time LOL. So tommorow im hopping to drop everthing in. and running
okay but how does it work out with the B18 pin height and compression ratio? I was told they were different from a20...
Ask 89t his setup runs good an he hasn't had any problems.
cricket's, Dam Rendon you really know how to kill a thread. LOL!
I have some eagle H beams i can compare to a old set of stock rods, but as far as the pistons go mine are dam near a flat top , pretty close to even with the deck or top of the cylinder. with the H beams.
well im not worryed. your setup is worryed so im ready lol. .....SO how i kill my thread LOL. o i know. i mentioned you huh LOL
You figured it out LoL...
Ok the OEM rod lenth from inside wrist pin to inside crank with out the bearing is
103mm
The eagle H beam is a bit longer at
106.04mm
the pistons I cant give any numbers on seeing that their in my engine.
If there is anyone with a b18a piston that can mic the top of the wrist pin to the top edge of the piston and add it to the post.
stock Is:
19.90mm
from top of wristpin to top edge of piston.
19.99mm wristpin
H beam wrist pin size:
20.94mm
now if we can get that final measurement we can see if there would be a differance mechanicaly or see if it will wash.
NOPE....sounds good. I need this info. there slighty taller but that doesnt matter......
So how far it sticks up when its at tdc?. i wouldnt imagine it would be much. Be nice to have a pic but you prolly wouldnt have one
Old motor is out took the crusie out to damn bluky an looks cleaner. Swap over all the parts to the temp motor. So all needs tobe done is drop it in. Going to clean up the engine bay a bit an drop it but the hard part is done. Pics to come
Lol yes sir. I had a crew of 4 helping me an my builder/tuner was doing all the head timing stuff
My tuner/builder is taking the timing belt shit off and swaping it over to the block im working on which is the temp motor.
So heartless
BOut half way....NOT
Motor is complete now just didnt show any pics...LOL
