Results 1 to 21 of 21
Thread: bleeder screws
    bridgewater.NS Canada
    Question bleeder screws
    does anyone know what size the bleeder screws are for my sei.i called honda and they said they're all the san=me size ,but they look like diff to me.
    snoopyloopy's Avatar
    Killa Cali
    Re: bleeder screws
    lol wut
    they should be same size between 88-89 lx-i and se-i since they use same calipers/rotors in front. not sure about between 86-87 lx-i/lx/dx and lx-i/se-i.
    Re: bleeder screws
    Are you trying to get bleeders for the rear or front? I know that both my rear calipers are the same as the front's on my LX.
    Re: bleeder screws
    I'm trying to find both front and back,i ordered a set for front from carquest.They said they had the back ones in stock.the old ones were chewed up and the holes were pluged with rust.the rear calipers were nseized and had to heat them and remove with vise grips.I'm gonna rebuild them when i can afford to.the pistons for both will cost the same as one rebuilt caliper.not sure how hard they'll be to put in .
    Re: bleeder screws
    The rear pistons screw out. I spent $30 to rebuild both my rear calipers. My pistons were in good shape.
    Re: bleeder screws
    yeah my pistons are pitted up pretty bad,honda wants like 60.00 each here.still cheaper than 130.00 each for calipers though,how hard is it to put the pistons and seal in?
    Mar 2005
    '89 Accord 4dr Lxi
    SF Bay Area - Eastbay
    Re: bleeder screws
    I just changed the rotors and pads on my LXi. The front bleeder screws were 10 mm, the rears (drum brakes) were 8 mm.
    Re: bleeder screws
    if you are going to replace them,go to advance or autozone and get the speed bleeder bleed screws,that's the brand name, they will make bleeding your brakes a whole lot eaisier they will be eithier an eight or a ten mm
    SEi User codyJDM's Avatar
    Apr 2008
    '88 civic wagon
    SoCal
    Re: bleeder screws
    It's really easy, I actually just done doing it to my LX-i 88-89 front brakes.
    Just make sure to thoroughly clean everything with brake cleaner, and remove any rust or buildup in the piston/cylinder walls with extremely fine steel wool.
    Re: bleeder screws
    are they aluminum pistons or steel? you shouldn't use steel wool on anything let alone aluminum,it inbeds metal particles which cause corroision of the aluminum. use emory paper or crocus cloth
    Re: bleeder screws
    I've never seen those before. Look pretty cool though. I might pick up a set.
    http://www.speedbleeder.com/
    Re: bleeder screws
    they eliminate the need for an extra person to pump the brake pedal
    Apr 2008
    '88 civic wagon
    SoCal
    Re: bleeder screws
    Sounds bad ass to me.
    Re: bleeder screws
    you connect a hose to them,then open the bleeder screw,they have a check valve to keep air out
    Re: bleeder screws
    yep get speed bleeders
    Nov 2000
    Re: bleeder screws
    So does one of these...
    http://www.keenzo.com/showproduct.as...1432126&ref=GB
    I only chose this site to show the product. I bought mine at Auto Zone several years ago. The vacuum pump can be used to actuate vacuum powered items on the car for testing as well. You can also use it to empty the master cylinder. Bleeding the brakes is much faster if you replace the fluid in the M/C first then bleed at the wheels.
    Re: bleeder screws
    Quote Originally Posted by DBMaster View Post
    oh now thats sweet! i must get that as its cheaper then buying speed bleeders for every car i own haah
    so thanks for the link man is it any cheeper at autozone btw?
    Re: bleeder screws
    I'd be curious to know how you get that vacuum pump to work. I've tried it on two different cars and each time, the pump pulled air around the bleeder screw, but no brake fluid out of the system.
    Re: bleeder screws
    did you open the bleeder screws first? and you need a resovoir for the fluid to go into,you can't just suck it up into the pump,or it will ruin the pump seals. there is a specific brake bleeding kit that is made for a hand vaccume pump.
    Nov 2000
    Re: bleeder screws
    The kit I bought was about the same $30 as it is online. It comes with the reservoir, plenty of clear hose (You could get more at Home Depot if you wanted it longer), and various size fittings for the bleeder screws. There are two important things to keep in mind when you are using it. Number One is open the cap on the master cylinder. You need to vent the system for rapid bleeding. Also, use the fitting that snaps onto your bleeder screws. The front ones are bigger than the back ones on my car. You loosen the bleeder screw just enough to allow fluid through it, but not so much that the vacuum pump will suck air around the threads. It's really easy to use and makes the job almost a no-brainer. It was definitely one of my more useful tool purchases.
    Re: bleeder screws
    Yeah, tried all that. No dice. Just got a lot of carbonated brake fluid. I'm thinking I'll try the speed bleeders.
  1. Brake bleeder kits?
    By paul in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-13-2009, 07:24 PM
  2. Vacuum Brake Bleeder
    By HondaBoy in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-23-2007, 02:30 AM
  3. plastic screws
    By Strugglebucket in forum Classic Honda Community Chat
    Last Post: 12-27-2004, 04:07 AM
  4. Russell Speed Bleeder P/N
    By AZmike in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-27-2004, 07:10 AM
  5. rear break bleeder screws keep snapping
    By meohmy01 in forum 3geez Accords
    Last Post: 02-09-2004, 06:48 PM
