Ok, I've been trying to find a diagram of the locations of all the idle adjustment screws, I know where the throttle stop screw is, that's obvious enough, I'm assuming the big ass black knob that's behind the carb and kind of inset into it is the idle adjustment knob, what I don't know is where the cold idle adjustment screw is, I've found many threads saying "this thread has a diagram of the locations of all the screws" and all the links are dead. I'm really dirty and I've been searching for awhile and would really like it if somebody could just tell me where it is lol.
Just to recap
The screw attached to the throttle cable is obviously the throttle stop screw
The big ass black knob, that's the idle adjustment knob right?
There's another screw that's facing outward on the driver's side of the carb, it's adjusted to linkage which I'm assuming is the choke linkage, not sure though, what is that screw? And **please** where is the cold idle adjustment screw? lol thank you
***edit
I went and looked at that last screw I mentioned that I wasn't sure what it was for
It's attached to linkage that leads into a hub of four vacuum lines, and also on the back of this hub there's another small screw
Is this the cold idle adjustment screw? Thanks again!
