Results 1 to 14 of 14
Thread: need gasket
    need gasket
    I can not find this in usdm. It is the gasket that goes under the torque converter solenoid set for jdm auto tx.
    Anybody that can help, or maybe get one for me and toss it in an envelope.?
    [IMG][/IMG]
    It goes to this...
    [IMG][/IMG]
    LX User evil88accordLX's Avatar
    Jul 2007
    gold 88 accord lx
    NWA (not the rap group)
    Re: need gasket
    make one with some red RTV sealant?
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: need gasket
    Have a PN on the solenoid?
    CARDONE SUCKS.
    Re: need gasket
    I will get that posted asap.
    You can not use rtv, hondabond or any thing like that on an auto tx, all it takes is one tiny piece to come off the glob to get into those small channels and block flow. It is bad enough to use rubber o ring type material, GM has major tranny failures caused by pieces of o ring sticking valves.
    Re: need gasket
    I am not exactly sure the purpose of this valving. I am not running any electronics and I was told you could keep the solenoids energized with the key on and it would work normally. Not sure about that yet.
    If I can see if the solenoids are opening flow or closing flow, I possilbley could make a block off plate.
    Other wise, it may be that I have to swap the internals with the A20 transmisssion, the bell housings are supposed to work, but my question there is why do they look so different.
    Jul 2007
    gold 88 accord lx
    Re: need gasket
    i meant actually making one, let it sit for a couple of days, then using it. the stuff cures into a very durable yet flexible rubber. but i see what you are saying about using it wet and globs falling off. that would be disastrous.
    Re: need gasket
    This sucks, there is not a number on the part. I cant even run the engine or tranny fluid shoots out.
    I am back to the drawing board on this one...
    May wind up using some king of goo.. I dont get all the channels this thing has it only needs to flow thru the solenoids and cross into the other orifice on either side.
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Re: need gasket
    Was your old gasket that bad? Its not reusable at all?
    carotman's Avatar
    Montreal South Shore
    Re: need gasket
    try to contact Honda of NZ.
    Thay can ship you parts.
    Re: need gasket
    Quote Originally Posted by bullard123 View Post
    yes it has a break in it, I may try some rtv if I can get it to come out in a very very small bead , thing is that stuff will not hold up saturated in ATF. If I can find out the fluid path of these orifices. I possibly could make a block off plate or either a custom made pneumatic line and just move the block somewhere else. That would involve threading the orifice openings though.
    Re: need gasket
    don't use rtv use this,and if you can find a gasket get more then one. http://www.amazon.com/Loctite-Gasket.../dp/B0002JMLMY
    Re: need gasket
    thanks but this is not really a gasket that needs alot of attention normally. And these solenoid blocks are stupid expensive from the dealer. I think I may have F'd up this thing when I was looking at it before I even installed the engine. Maybe worst case scenrio is no 5th gear auto, I just need to know how it is supposed to function. I also realize not alot of people even bother to study these so I am just prying you all for ideas. thanks
    Re: need gasket
    well that if for forming o rings.
    Re: need gasket
    Ok I found some permatex RTV that is labeled "exclusivley for Automatic Trans" it stands up to ATF and does not peel away. I tried it but it says best to have a 24 hour cure before exposure.
    It is grayish silver colored, reminds me of a mixture of regular old school permatex form a gasket and RTV>
  1. Carburetor Rebuild , Top Gasket Printout / Other Gasket Info
    By Knowledge Base Admin in forum Carburetor Tech
    Last Post: 06-24-2019, 09:02 AM
  2. Replies: 16
    Last Post: 11-30-2003, 02:43 PM
  3. Oil Pan Gasket
    By BMS in forum Carburetor Tech
    Last Post: 10-17-2003, 10:51 AM
  4. help.. i think its gasket....
    By Iceburn in forum 3geez Accords
    Last Post: 08-17-2003, 11:06 AM
  5. Oil Pan Gasket.
    By BITESIZE in forum 3geez Accords
    Last Post: 07-17-2003, 08:17 AM
