Results 1 to 11 of 11
Thread: Stock Suspension Height
    Aug 2008
    I was wondering what the stock ride height on a 3g accord is? Like from the center of the hub to the fender. I'm looking for that measurement so I can tell how much my stock suspension has sagged, how much my springs lowered my car, and how low I can go... I need to return my springs and get new ones because they lowered different ammounts on each corner and I would like to know how much lower each corner is from stock so I know what springs will work and what will be too low.
    Thanks!
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Re: Stock Suspension Height
    Lowering different amounts is sort of common -- I remember the driver's side of my 3g was lower than the passenger side when I put new h&r springs on. I think it has to do with bushing and strut wear.
    my driver side of the car is lower even with lowering springs. i would replace the shocks with tokicos since they are the best for the money...lowering springs also if you what a sporty suspension. i would replace the ball joints because you never know when they are going to go
    Aug 2008
    installed with the springs was a set of tokico blues
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Probably weird bushing wear that all these cars have then.
    I wouldn't bother returning the springs since another set of springs will most likely do the same thing.
    I had put new tokicos on with my h&r's too, and still did the same thing.
    Aug 2008
    now that i think of it.. we had to swap out a bushing in the LCA that the fork that the shock mounts in bolts to (i hope that makes sense). could that be the 3/4" that im out? so since both sides were the same with the stock suspension.. if I put in a new bushing on the drivers side would it level out a bit?
    make sure to get an alignment also
    Aug 2008
    once i get it all done i will be getting an alignment... once im done fucking with the suspension parts....
    Aug 2008
    would that one bushing be enough to lift the pass. side 3/4"?????
    The only thing I could think of is maybe where the fork goes to the stut housing its slipped some how or not put together correctly.
    Aug 2008
    well i am going to pull both front shocks today... and swap springs (left and right) to rule out a defective spring. and i will double check and make sure the shock is mounted correctly in the fork. but i doubt it is that because of the groove in the shock that the clamp bolt in the fork goes through... i dont see how it would come out of there... we'll see tonight.
  1. F.S. Rear Suspension Components(Stock)
    By Rich87HB in forum Trading Post
    Last Post: 04-06-2004, 07:02 PM
  2. replacing the stock suspension
    By RustyHo88 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-12-2003, 07:14 PM
  3. stock suspension.........leans in turns!
    By bradccool in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-19-2003, 03:44 PM
  4. 17's on Stock Suspension
    By PogiLXI in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-10-2003, 06:40 AM
  5. acura stock suspension
    By shepherd79 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-02-2002, 08:42 PM
