Results 1 to 25 of 35
Thread: beeping thing
    LX User rfiks's Avatar
    Sep 2008
    88 accord hb dx
    el paso
    beeping thing
    does any1 know where the beeping thing in the dash is located so i can it, or does any1 know where i can find the guy that invented this worthless peesa S#!t? i gave my friend a ride home 2day and i beep-beep-beep-beep-beeped alllllllllllll theeeeeeeeeee waaaaaaaaaayyy home... Please Help Me!
    Re: beeping thing
    it's located on the cover below your steering wheel I think
    Re: beeping thing
    Seat belt charm ?? You have to completly shut the car off and then on again to reset it.
    Sep 2008
    88 accord hb dx
    el paso
    Re: beeping thing
    i no i want to burn that little beepering thing where is it?
    Re: beeping thing
    Quote Originally Posted by rfiks View Post
    Read. Its mounted to the panel under the steering wheel. However, if you remove it your dash lights won't work.
    Re: beeping thing
    It's always a wonderful feeling when you find that thing, remove it and smash it to powder with a sledgehammer. Right up there with peeing off an overpass.
    LX User jpetrovic's Avatar
    Mar 2007
    1988 Accord Lx-i
    Plano, Texas
    Re: beeping thing
    i know about the one under the stearing wheel... But ive never herd that oen beep.. the one i always hear beep is a white/gray box its litterly a few inches from the gas pedal under the center console where the raido sits all u do is pull it off the brakets and disconnect the wire.
    DX User l75eya's Avatar
    Jun 2008
    1987 Honda Accord DX Hatch
    Union City, New Jersey
    Re: beeping thing
    I like my seatbelt chime. It's always a fun topic for conversation when I'm giving somebody a ride and it starts beeping out of nowhere (2 to 3 times a week).
    Some suggestions
    Passenger: "What's that noise?"
    Me: "What noise?"
    P: "That beeping noise.."
    M: "Beeping noise? What beeping noise?"
    or
    P: "What's that noise?"
    M: "I don't know. One day I saw somebody crawling out from underneath my car with a pair of wire strippers, zip ties, and duct tape. Ever since then my car keeps beeping and sometimes I hear a ticking noise too."
    LXi User EX-ileAccord's Avatar
    Feb 2005
    89 accord EX-i 88 accord hatch s
    NS, Canada
    Re: beeping thing
    There is a gray box bolted under the radio, behind the ashtray. Unplug that and it will all go away, there is a relay under there too dont unplug that or the car will not start.
    Sep 2008
    88 accord hb dx
    el paso
    Re: beeping thing
    Quote Originally Posted by l75eya View Post
    Some suggestions
    Me: "What noise?"
    or
    lol ile try that. thanx every1 for your advice! if and when i find it-YES! im guna smash it and maybe bernit, i might even post pix of the aftermath..
    Aug 2008
    1987 honda accord lx-i
    Re: beeping thing
    sweet honda carnage.
    Re: beeping thing
    Quote Originally Posted by EX-ileAccord View Post
    don't unplug that box,it controls your sidemarkers too,it has several different functions
    Re: beeping thing
    mine talks to tell me the doors are open,but it shuts up after three attemps
    Re: beeping thing
    Typical isn't it? There isn't a person in the world who doesn't hate that racket, yet every car in the world tries to make the module as difficult as possible to remove.
    Feb 2005
    NS, Canada
    Re: beeping thing
    doesn't do anything but control the door, headlight, and keys in the ignition beep on my car. I have had it removed for years, and it has not affected anything.
    Re: beeping thing
    might be different on your car,on the US cars it controls the side markers also. they alternate with the turn signals and that box controls them.
    Sep 2008
    88 accord hb dx
    el paso
    Re: beeping thing
    well now that u mentioned it... my front corner lights work but they dont blink.
    Re: beeping thing
    My box is completely gone too. I'm pretty sure that my lights are okay, though.
    Re: beeping thing
    ok so i have a wired prob when i start the car with the door open my beeper beeps and wont stop if the passenger gets out of the car and i dont stop the engine the seatbelt light blinks and beeps and wont stop
    unless i turn the ignition orf and restart witch i normally do while driving so i dont wast gas restarting lol
    Aug 2008
    Re: beeping thing
    hm what about pulling it n then installing some sort of pulsing relay just for the blinkers, just a thought.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: beeping thing
    Does the door light light up? Chances are the switch in the door latch isn't making contact. Replace the latch. The seatbelts are electrically controlled by these and will not lock up with the door "ajar".
    CARDONE SUCKS.
    Re: beeping thing
    it shows on the wiring diagram that is the box that causes the corner markers to blink, i know i tapped both front corner markers off of it to run the sidemarkers,I think if you unplug it the lights it stay steady,not sure but thats the control box for them. there is a beeper thing built right into the box, if you could figure out how to get the box open, you can remove the piezoelectric element that causes the beep. there is also another one in the overhead console piece on lxi's, I got one to put the xm console in my dx,and it has a beeper in it,as well as the light up warning. you can remove the beeper piece easy from the overhead console.
    Re: beeping thing
    You're right. My corners light, but they don't blink. That's an irritation I can live with. The beeping is not.
    Re: beeping thing
    if you can find an extra box i will open it up for you somehow and disable the noisemaker
    Re: beeping thing
    I might take you up on that. I don't seem to have a headlight warning chime anymore which is a big problem. It's always foggy here in the winters and I've left my lights on more than once. I'd be willing to pick up a module just to get that back. I'll grab one the next time I'm at the junkyard. Thanks!
  1. Do you want this thing?
    By Tommy AC89 Thailand in forum Interior & Exterior Care
    Last Post: 07-20-2009, 11:01 PM
  2. Reverse beeping noise?
    By Cancer in forum 3geez Accords
    Last Post: 06-13-2006, 03:51 PM
  3. Is there such a thing?
    By Art 1 in forum Classic Honda Community Chat
    Last Post: 10-31-2003, 09:17 PM
  4. Next Best Thing?!?!?!?!?!?!¿
    By Nate2310 in forum Performance
    Last Post: 11-07-2002, 06:34 PM
  5. Annoying Beeping
    By SteveDX89 in forum 3geez Accords
    Last Post: 06-03-2002, 06:32 PM
