Results 1 to 10 of 10
Thread: heat problem
    Oct 2008
    89 accord 2 door dx
    heat problem
    Ok I just got back from my much anticipated inaugural drive which was a blast bone stock can't wait for the upgrades but i have. No heat but also no leaks or pressure leaks and the coolant is fine thanx in advance
    Re: heat problem
    Check to make sure that the valve is opening by the firewall. If it is, make sure you don't have air in the system.
    Oct 2008
    89 accord 2 door dx
    Re: heat problem
    Like the heat valves in old cars and big rigs ? Just turn the knob kinda and walah I have heat
    Re: heat problem
    Yeah there is an on/off valve that turns on the coolant with a cable attached. It might be froze up or the cable end is bad.
    Oct 2008
    89 accord 2 door dx
    Re: heat problem
    where abouts is it located?
    LX User Lil Mike's Avatar
    Toronto, Ontario
    Re: heat problem
    follow the coolant lines that go into the firewall it will be on one of the two lines.
    i know its a bad picture but hope you get the idea
    http://img143.imageshack.us/my.php?i...5144001gi3.jpg
    thanks mkymonkey
    Oct 2008
    89 accord 2 door dx
    Re: heat problem
    i found it it seems that the cable is working so maybe the valve inside is stuck i am soaking it in penatraiting oil over night so i guess we'll see in the morning does any 1 have experience changing 1 cause it looks wicked fun
    Re: heat problem
    Its just two hose clamps and a cable. Shouldn't be hard.
    Oct 2008
    89 accord 2 door dx
    Re: heat problem
    thanx the only other thing im thinking is heater core if i leave the fan off for a few minutes then turn it on it blows red hot for like 2 mins then luke warm at best unless i shut the fan off again and when im sliding the heat switch back and forth from cold to hot the temp changes so im really thinking heater core
    Toronto, Ontario
    Re: heat problem
    alright so we narrowed it down to a plugged heater control valve or a plugged heater core.
    i would try flushing out the heater core by taking both the hoses off from the firewall and get a garden hose and run water through one of the openings that go into the firewall. and let the water come out till its clean. there shouldnt be and pressure when you are trying to flush it out.
    secondly if you haven't taken the heater control valve off i would take it off and inspect it to see if there isn't anything plugged up in there.
    be prepared for a big sticky mess just make sure when your done to top your coolant off.
    thanks mkymonkey
  1. Replies: 19
    Last Post: 05-05-2012, 02:35 PM
  2. Heat Problem....
    By Christofur in forum 2geez Tech & Performance
    Last Post: 12-10-2011, 08:48 PM
  3. Heat Problem
    By Nasen88accord in forum 3geez Accords
    Last Post: 02-16-2005, 08:33 AM
  4. MPG/Heat problem solved?!
    By johnwc723 in forum 3geez Accords
    Last Post: 02-02-2004, 10:48 PM
  5. Need Better Heat
    By BIGEEZ in forum Classic Honda Community Chat
    Last Post: 12-02-2003, 08:47 PM
