Results 1 to 13 of 13
Thread: Needed: ECU pinouts
    carotman's Avatar
    Montreal South Shore
    Needed: ECU pinouts
    Hi guys, I was wondering is anyone got the ECU pinout for those cars:
    88-89 Prelude SI (pk2 ECU)
    89 Accord LX-i
    I need this for my JDM B20A Project.
    Thanks
    10/Honda/Ridgeline
    NJ
    what is a pin out?
    carotman's Avatar
    The description of what the pin on every connector does.
    Like (this is an example)
    Pin A1:O2 sensor (-)
    with this, I'll be able to switch/add wires for my B20A
    '85 lude
    houston
    i used to have the 89 LXi, pretty sure i saved it but it will take some digging.....
    YK86's Avatar
    Oct 2000
    BC, Canada
    This is out of the 1990 Prelude service manual in the 2.0L section.
    And the full version with wire colors.
    www.b20accord.com
    YK86's Avatar
    Oct 2000
    BC, Canada
    Sorry, it's a bit big but when I shrunk it down, it become very hard to read even when zoomed in (when it's zoomed, the writing was all blurry).
    www.b20accord.com
    carotman's Avatar
    Thanks for your help Yasu!!!
    I just hope that it's the same for the 89, There shouldn't be any problem.
    '85 lude
    houston
    gonna be some diffs. but im not sure about the B20A. the 88-89 lude was like the accord. 2 O2's and secondary butterflys in the plenum. they ditched that for 90-91
    carotman's Avatar
    I thought it was the opposite, they had 2 O2 sensors in 90-91 (Pin C16 and B11). However, the chilton maual says they got 2 O2 for 88-89 too.
    I'm all mixed up now
    I wanted the 88-89 cause I didn't want to switch manifolds on the B20 (because of the 2 )2 sensors
    The IAB was present in 89 tough and they had 1 O2
    What's the ECU number for Ludes 90-91? I already got the PK2 from an 89 Lude
    carotman's Avatar
    I just checked the part numbers for the ECU on www.slhondaparts.com
    All the 2.0SI Preludes from 88 to 91 use that ECU
    37820-PK2-A00
    Mine is
    37820-PK2-6630
    I guess it's because it is a Canadian model.
    Also, All years Preludes seem to use a 2 O2 sensor setup (from what the site says)
    Anyone can confirm that?
    '85 lude
    houston
    oh ya. the changes were for the 2.1. forgot they had both the 2.0 and 2.1 in 90-91
    Aug 2000
    2003 Nissan 350Z/2002 GMC Envoy SLT/1986 Accord EXi
    Ontario, Canada
    All B20A5 Preludes use 2 oxygen sensors.
    The 90-91 B21A engines use only 1 O2 sensor as well as a single stage intake. That being said, the 90-91 B21A ECU cannot be used with the JDM B20A since it is OBD-1 and therefore will not plug in to the Accords OBD-0 connectors, unless an adapter is made.
    Major modifications include:
    JDM Accord B20A engine swap
    89 SEi rear disc conversion
    3geez member since Aug 18, 2000
    carotman's Avatar
    Haaaa that enlightens me!
    Thanks AccordEXI
    I did do some research and found out that the B21 had no dual stage and used a heater O2 sensor on the downpipe (same location as the 90-93 accords)
    So, I DID get the correct ECU.
    Now, I was wondering if I can use the B20A distributor and crank sensor or do I need to get the B20A5 ones.
    If I can use the B20A parts, does the 86-87 integra distrib cap fits on the B20A distributor.????
    If not, does any USDM cap will fit? (and rotor)
    Thanks
  1. Mot Fail!! Big Cost. Advice And Or Offers Needed! Steering Rack Needed!
    By ESDEEZ in forum Classic Honda Community Chat
    Last Post: 08-12-2007, 08:19 PM
  2. 3G ECU pinouts
    By newaccorddriver in forum Performance
    Last Post: 01-08-2006, 10:08 AM
  3. [Engine & Transmission] Ecu - codes , pinouts , part numbers , obd explained
    By Mike89Accordcom in forum Frequently Asked Questions
    Last Post: 09-27-2005, 10:51 PM
  4. ECU Pinouts
    By racetek82 in forum General Engine Swaps
    Last Post: 01-17-2005, 11:08 PM
  5. i need pinouts for a 87 integra
    By 88LXI in forum 3geez Accords
    Last Post: 02-01-2003, 08:44 AM
