what kind of clutch do you have??? i need a new clutch & im seeing these "gripforce" clutches on fleebay... any advice?
go with clutchnet for performance clutches
i have a exedy clutch
Exedy and LUK are the same. The exedy one I put in this past June was stamped LUK
Phil
the LUK cluch teeth look smaller than the exedy clutch. the LUK one is cheaper but cheaper is better 40% of the time & if i get the LUK just to save $20 um guna bAND THEN
. so i will save myself a some nervz and buy the good stuff!
Remember that the correct LUK clutch set # 08-008.
Someone on ebay is listing a LUK rep set for a lower price but doesn't have the correct part number. Verify just to be sure that you are indeed getting the correct set.
Phil
The Exedy I put in is LUK, so its all good. No problems to date.
Phil
