Results 1 to 9 of 9
Thread: New vacuum gauge
    New vacuum gauge
    I so rarely offer anything up in the Performance section, I figured I could put this here. I just installed my new vacuum gauge tonight and I'm really excited.
    This will give me a lot more insight into how my valve train and combustion chamber are working. It will help me conserve fuel and keep me apprised of any vacuum leaks that may spring up.
    Re: New vacuum gauge
    w00t looks good
    SEi User codyJDM's Avatar
    Apr 2008
    '88 civic wagon
    SoCal
    How does one install a vacuum gauge? That is a bad ass setup!!
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    It's mechanical, so you just run the nylon tube through the firewall, and tap into one of the vac lines from the intake manifold (preferred spot is probably to T into the vac line that goes to the fuel pressure regulator). Just like a boost gauge. The nylon tube attaches to the back of the gauge.
    I agree, looking good
    How much and where did you get that Vac Guage? I want one for my Truck
    looks good a lot of people forget how useful a vaccume gauge is, will tell you more information then almost any other gauge if you know how to read it
    Yeah, like 86AccordLXi said, just run the included vacuum line through the firewall and you're good. I ran the vacuum line to the spare vacuum port on the intake (has a cap). It was a little sloppy on the nipple, so I ran a short length of Honda line from the port to a T-adapter (also included) and then to the gauge. Then I plugged the spare port on the T-adapter with the cap from the intake. Hardest part (for me) is wiring the lights.
    I got it from Amazon for $40. It was free for me because I used my Visa points.
    here you go http://www.secondchancegarage.com/public/186.cfm this will give you a scenario for each thing and an animation of the needle and an explanation.
  1. How to read a vacuum gauge
    Last Post: 12-20-2010, 05:33 AM
  2. Vacuum Gauge Reading , What Does It Mean ?
    By A20A1 in forum Carburetor Tech
    Last Post: 06-15-2010, 05:53 PM
  3. Vacuum Gauge
    By HondaBoy in forum 3geez Accords
    Last Post: 12-15-2006, 11:55 AM
  4. Vacuum Tank , vacuum hose
    By En-g in forum 3geez Accords
    Last Post: 09-06-2006, 04:32 PM
  5. what is a vacuum gauge?
    By myaccord7 in forum 3geez Accords
    Last Post: 08-13-2004, 05:47 PM
