Results 1 to 9 of 9
Thread: crank bolt
    DX User chero's Avatar
    Nov 2008
    62 Ranchero 200hp
    Slowdeatha,Tx
    crank bolt
    Yes,I dropped the water pump bolt on my son's 87hactchback.which way does the crank bolt come out?needs new gasket anyway.
    Re: crank bolt
    Lefty loosey. Maybe a magnet? Take the top timing belt cover off and peak down there.
    Re: crank bolt
    Good call OldBlue. Harbor Freight sells the long flexy rods with magnets on the end for real cheap. Try snaking it down there first. You might also just remove the bolts around the bottom of the cover and see if you can pry it open enough to get it to fall out.
    Otherwise, you're in for a lot of work and if you're going that far, might as well do a full timing belt service.
    Oh, and welcome to the forum. Let us know how things end up.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: crank bolt
    Yep, lefty bolt. I agree, might be able to fish a magnet down & snatch it up.
    Hope you got a good impact hitting some serious torque w/ impact socket, because usually the crank bolt is on real tight, like breaker bar & socket busting tight.
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Re: crank bolt
    three shops three broken bolts later and i tried taking a broken socket and securing a metal screw down fastener around it and viola! + 4 ft breaker bar of course. good luck!
    Re: crank bolt
    Quote Originally Posted by Demon1024 View Post
    I think I'd have a nice chat with whoever put that on last. There's no excuse for that.
    Nov 2008
    62 Ranchero 200hp
    Slowdeatha,Tx
    Re: crank bolt
    Thanks,all.Since I only have 32'' breaker bar,I used an impact socket and hammer impact.4 good hits with 5# did it.now he's getting a new belt while I'm in here.On the bolt..thought I might be dealing with something like a 413 left-handed chrysler ag motor,didn't want to tighten it.
    Now I'm going to kiss my 62 ranchero right on the modded 6 banger.
    Re: crank bolt
    Quote Originally Posted by chero View Post
    get a new timing cover gasket set,nappa has em and make sure the cam or main seals aren't leaking while you are in there. did you get a belt or a set,you can get a set with a new belt and a new tensioner.
    Re: crank bolt
    Replace the tensioner while you're there. The previous owner's mechanic didn't do it and only replaced the belt. 30k miles later, my tensioner went.
  1. The Pre-'90 Gawd Almighty Crank Bolt Redux
    By edk in forum 3geez Accords
    Last Post: 10-09-2011, 08:42 AM
  2. Crank Bolt = Bitch... Big Thank You!
    By DocStirling in forum 3geez Accords
    Last Post: 07-18-2009, 07:34 AM
  3. Crank Bolt pat on A20 & B20
    By 86LXItooFAST4me in forum 3geez Accords
    Last Post: 08-01-2004, 11:08 AM
  4. Removing Crank Pulley Bolt - Phase VII
    By it's paid for in forum 3geez Accords
    Last Post: 12-07-2003, 04:03 PM
  5. Crank bolt
    By Mac in forum 3geez Accords
    Last Post: 07-28-2003, 11:21 AM
