Results 1 to 22 of 22
Thread: Header Studs
    Exclamation Header Studs
    I was woundering if are header studs pressed in or screwed in? if so all i got to is screw it out with visegrips maybe? whos done it an how much of a pain this is going to be. i broke 1 an can still grab w/out the thick washer.,i just want to replace it. i got out of hand when putting my manifold on lol.
    Rendonlxi
    Re: Header Studs
    Yeah there screwed in as far as I have heard. Double nut them maybe but its steel on aluminium so theres gonna be trouble. If you can heat up the alum a little it will expand and hopefully help get them out.
    Best bet it to try and use what you have it can turn into a mess.
    Re: Header Studs
    ya i would try a double nut setup
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Re: Header Studs
    from waht it sounds like, he's bust half a stud off so double nut might not work.
    there are a few stud extractors on the market that work all right.
    there are easy out .which are only really usable if the stud is bust off flush.
    the ones i like go over the stud and grip the sides of it, but require most of the stud be there to get a decent grip.
    but vice grips and a can of wurth rost off ice or similar may be the go if either of the above are out of the question
    Re: Header Studs
    yea its busted off flush and i can still grabs with a nut with the manifold on but not much 3 maybe 4 turns but i just want to replace it...ill see what i can do or have a friend give me ahand
    Re: Header Studs
    do you have access to a welder? you can screw on a nut and weld it to the broken off part. then you back it out with a wrench. I got sick of messing with the studs and helicoiled everything. I also went to a 5/16 fine on one end in the head, and 5/16 coarse on the manifold end. thats a common exaust stud. i had to drill the holes in the manifold to make it just slightly bigger. not much.
    Re: Header Studs
    sounds like a plan....i was thinking of that to but what if it breaks again lol...well worse case is just tap and die the fucker..thanks again..
    Rendon
    Re: Header Studs
    http://www.sears.com/shc/s/p_10153_1...0070921x00003a
    might be a lil expensive but they will get used more then you think lol
    Re: Header Studs
    I drove around for who knows how long with an exhaust manifold nut missing. Never had any noise or other problems.
    Re: Header Studs
    well its on now and if it leaks im going to let it warm up for 5 minutes to let the alum. explan then take take some PB and vise grips and let her rip i did some research shouldnt be that much of a pain...im just thinking bout it way to much lol....im lucky its didnt break flush with the head.
    Rendon
    Re: Header Studs
    when i was changing my header one of the tips broke off so i just didnt use the washer for it and it still fine
    LX User greentee76's Avatar
    Feb 2008
    1988 Honda Accord LX 5sp
    Kalamazoo,MI
    Re: Header Studs
    Yeah I don't have washers on two of mine. I also don't have any flexpipe in my exhaust so it moves the whole exhaust when the engine moves. The exhaust mani is still nice and tight.
    88 LX 5spd l 32/36 weber l KYB GR-2's l Refreshed A20A3 engine l
    Re: Header Studs
    i should b fine....seems like im not the only one lol.
    SEi User
    Feb 2004
    Panama City, FL
    Re: Header Studs
    I've broken a few of those. I need to take them back and make them replace them.
    Pgm-fi conversion 4-16-05
    OBD1 11-25-06
    Turbo 2-26-07
    Re: Header Studs
    Harbor Freight has kits for $8. You won't feel bad breaking those.
    Re: Header Studs
    damn cheap..
    Re: Header Studs
    ya buts craftsman i wont feel bad eather having them replace for free lol
    LXi User -$MOKIN-'s Avatar
    Apr 2006
    1989 HONDA ACCORD LXI
    Re: Header Studs
    HAD same problem. So i went to the pull and pay and got me a new one with o2 sensors for 23 bucks
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: Header Studs
    Quote Originally Posted by EricW View Post
    Good luck. They don't have the warranty on stuff like that.
    CARDONE SUCKS.
    Re: Header Studs
    I'm finding that a lot of Craftsman stuff is really overbuilt and awkward. I have a deep well impact socket that I use for lug nuts. I can barely fit it into some wheels. It's decidedly thicker than my Harbor Freight sockets. The Harbor Freights are not as strong, but I'm okay with that.
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    Re: Header Studs
    they should back out without much trouble, just soak them with PB Blaster everyday starting tonight, and by the time Saturday comes around, they'll damn near back themselves out. Mine accidentally came out when I was trying to back the nut off the stock exhaust manny. I was like WTF? Two birds, one stone with that one b/c I had new ones ready to replace the original rusted up ones.
    -Mark D.
    Re: Header Studs
    Thanks mike...i got it all handled i had a exhuast leak anyway so i went ahead replaced it.
    Rendon
  1. main studs
    By hondaman1986 in forum Performance
    Last Post: 02-03-2008, 07:53 PM
  2. stripped studs
    By coope in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-29-2007, 02:34 PM
  3. wheel studs
    By b20a86lude in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-31-2004, 03:28 PM
  4. Head studs or not?
    By Rendon LX-i in forum 3geez Accords
    Last Post: 02-26-2004, 07:27 AM
  5. replacing wheel studs
    By staticpat in forum 3geez Accords
    Last Post: 06-18-2002, 02:21 PM
