great news guys.. i got the bearings today.. so im going to let my car cool off over night and get to fixing it tomorrow.. i saw the stamps on the journals on my spare block sitting in my garage.. its 1.2.3.4 huh? thats what i saw.. and the 1 and 2nd journals have an F on it is this what im looking for?
-Tom
1988 4 Door Lx-i 5-speed
364,XXX and counting :]
Not really sure. Keep doing your research I never actaully done bearings on any Honda motors and I know less about the A18. The chart with the manual is the best bet.
will the oil pan from the a20a3 fit on the a18a1? i noticed a big dent from where my cv blew out and i dont wanna run it like that
-Tom
Yes, the oil pans are compatible if not identical.
If you want you can download a PDF Prelude manual from here:
http://bluegreenlabs.com/Prelude/Svc...l%20Manual.pdf
I'll warn you now it's nearly 90MB so it will take awhile. Pages 80-81 describe the bearing setup. The procedure is the same for the A18 and A20.
Incidentally, when I rebuilt my engine I used Toga HP bearings, which are a high performance tri-metal bearing (supposedly). Anyway they only come in one size so when I assembled the crank and rods I checked the clearances with plastigage. They all came out well within the normal spec. So I think as long as your crank isn't massively worn you'll be fine.
C|
today is the worst dam day ever.. i changed the rod bearings and it still knocks like hell.. what can it be?? this is really ticking me off
EDIT: talked to a mechanic friend this morning and he suspects it to be the mains.. what do you guys think?
-Tom
-Tom
It could be mains. It could be wrist pins. It could be piston slap. You won't know for sure until you pull it apart.
I don't mean to rain on your parade, but this has all the hallmarks of something that's going to end badly. You're trying to fiddle and fart away a very big repair. The very best you can hope for is to spend a chunk of money and a lot of time and still have an engine that needs to be replaced. That doesn't make a lot of sense to me. Unless the knocking is so loud that potential employers can hear it when you drive up, your time would be better spent looking for work.
hmm my mechanic friend told me that piston slap is out of the question but mains or wrist pins might be an option.. will mains from my a20a3 fit the a18a1? i have my a20 block in my garage and im willing to get the mains out of that one to prolong the motor just a little bit longer.. but if i have to ill run the motor like this til i get it fixed
-Tom
The A18 and A20 use the same bearings, so yes you can swap them.
If you have the time I suppose it might be worthwhile to try the mains, but I wouldn't hold my breath that that's the problem. If it is the wrist pins though there won't be much you can do anyway without more serious work. So if swapping the mains doesn't fix it I would just put in 20W50 oil, load it up with thickeners, and run it until it dies.
C|
wow.. so everything is interchangeable right? same motor just different cc's
and i have the pistons to my a20 also.. so it worst comes to worst i can use the wrist pins an rods from the a20a3 on the a18 piston.. is that plausible? or are the wrist pins different for the two?
-Tom
The A20 is really just an A18 with a larger bore and a different head. But many of the head parts are interchangeable too. So yeah, you could use the A20 rods and pins as well. If the problem is in the pin area though it's most likely the piston itself is worn, because it's aluminum and the pins are steel. The only way you'll know is to pull the pistons out. It might suck to get them back in if you don't have ring compressor though.
C|
ill probably just reuse my rods.. just get a set of pistons from the scrap yard when i get some money.. but yeah the knocking is betting louder and it doesnt sound like its rod bearings or mains.. it sounds like its where the head is at but its too much to be piston slap
-Tom
Don't suppose you could get a video of the noise could you?
Are you sure it's not a valve problem then? Pop the valve cover off and take a look.
C|
well dr.. i could try to get a vid up soon.. i just gotta find my camera.. and Cl i highly doubt its valves.. its too much of a clunk noise to be valves
-Tom
bad news guys... motor went out before i could get the vid up... sounds like one of the pistons shattered inside the block.. i have no options but to sell my 3g.. its sad to say but i just cant afford to keep up with the fucken bug in the motor.. so im selling my 3g.. ill ask for 500 for it as is.. let me know if anyones interested
-Tom
Take the head off and see what happened for us it can go into the wiki.
Sorry it turned out bad.
well she still runs but it feels like shes running on 3 cylinders.. and theres a nonstop rattling.. but i want to keep it together and see if i can get more for it.. i would take the head off and see what caused the mayhem but i want to see if anyone would take it like that.. im positive that all it needs is internals.. i found a vid of a d16 blown up on youtube and mine sounds louder then this guys.. heres the vid to give you guys a rough description on how its running as of now.. my cam is no where to be found so i cant put a vid up =/
http://www.youtube.com/watch?v=E-tNS...eature=related
-Tom
Best you could do is disable that cylinder. Either pull the rod and piston out the bottom if possible or out the top and leave it running on 3. The condition of the plug will tell which is bad.
-Tom
1/2 off everything sale at pick-a-part on jan 1st!! www.pickapartauto.com
...If you're ever confused about anything in life... it probably has something to do with money$...
ok guys.. took the head off the block.. looks like the crank is broken b/t number 2 and 3 cylinders.. ill have the vid up in a lil while.. gotta upload it.. but if you guys have myspace.. look me up and ill have a folder with the pictures i took of the teardown
-Tom
