I have read that the only way to remove my alternator on my 89 LX (carb car) was to remove the half-shaft,i do want to tell everyone that if you remove the 2 bolts from the driver's side motor mount and put a block of wood on your floor jack you can jack up your oil pan about 1 to 2 inches and say hello to your alternator that will be laying on the ground by your driver's side tire in 5 minutes tops.Good Luck! i had my alternator in my hands and battery out and on charger in 30 minutes.
