I replaced the bad cam oil seal and the timing belt. To clean off the copious amount of oil in the timing belt compartment, I liberally used Simple Green. Then, I (knowing SG is corrosive) sprayed the compartment with lots and lots of water. Now, there is a new whining noise. It sounds like it's coming from a pulley. Did SG caused this? Is it possible for SG to seep into bearings and destroy it? Or, was it coincidence?
