cut the end off of the original PS hose at the pump,going to mig weld on a steel AN fitting on to the steel part that goes to the pump, the line wasn't leaking,but i just can't trust a 23 year old high pressure lihe,going over the exaust manifold. i've put too much work into that engine bay to risk a fire to save a few bucks. one thing i noticed,the line looked ok on the outside,but the inside was badly dry rotted. it's a steel line about a quarter inch in diameter wrapped in there. I will tell anyone if you care about your accord,replace that line if it's old. there are places that will make you a line,or you can get an aftermarket one. there have been a number of fires on here related to that line spraying PS fluid on the manifold. personally i think they were idiots for running it where they did. I'm sure there were a lot more fires then what we know about here. did they think that lines never go bad?
