Results 1 to 7 of 7
Thread: Brake pedal help
    LX User canadian357's Avatar
    Feb 2008
    '88 Accord LX, '87(?) LX-i
    Edmonton, Alberta, Canada
    Brake pedal help
    This one is fairly urgent, seeing as how a turn in the weather has turned everyday driving into ice-racing up here. Basically, whenever I apply the brakes in my car, I have to depress the pedal about 50% of the distance to the floor before I get any brake response. After that my brakes kick in OK (but unfortunately I have to do my rear brakes soon, which should be OODLES of fun in -20 celsius in an unheated garage). I'm wondering what could cause the sponginess of my pedal. The only reason this matters to me is i want quicker braking times (almost hit a stray cat). Is it anything simple as i hope, like tightening a few bolts or something?
    The car - '88 LX Carb, rear drums, 100% stock
    Re: Brake pedal help
    Moisture in old brake fluid might be the culprit here. Try removing as much fluid out of the MC and putting in new brake fluid for a quick fix.
    The rear brakes may need to be adjusted is all. They dictate the pedal height and feel. You can cheat a little and run with the E brake up a few clicks to take up the distance for a temporary fix. The shoes must be very very close to the drum to be correctly adjusted. Just so you can barely slide the drum on.
    Feb 2008
    if its the rear brakes that dictate it, then I know what it is. I've gotta do my shoes right away, so thats probably it. How long should doing the brake shoes take? its the first time i will have worked on drum brakes.
    LX User greentee76's Avatar
    Feb 2008
    1988 Honda Accord LX 5sp
    Kalamazoo,MI
    Being your first time I'd count on a couple hours probably. I did mine in about a hour with some help from one of the mechanics here at work.
    Make sure your adjusters are freed up and the teeth are not stripped off them. I need to replace mine with some from the j/y I need to free up.
    88 LX 5spd l 32/36 weber l KYB GR-2's l Refreshed A20A3 engine l
    DX User l75eya's Avatar
    Jun 2008
    1987 Honda Accord DX Hatch
    Union City, New Jersey
    Just curious, does anybody else have an issue with the ass end of these cars being so light (say if you have absolutely nothing in the car) where, say if it's raining or something, it's REALLY REALLY easy to lock up those back wheels? Winter is gonna be FUN! Maybe there's air in your lines shenaniganas? Although the travel time for the shoes to hit the drums sounds more likely if your shoes are worn. I hate drum brakes.
    Quote Originally Posted by l75eya View Post
    I have rear disc brakes and I didn't change the front brakes over so it locks up even worse.
    once i was testing my rear disks and i pulled up the e break and my rear started to lock up...with minimal effort
  1. brake pedal
    By Warren 88 Accord in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-31-2011, 05:05 PM
  2. brake pedal height
    By bushbean in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-02-2011, 09:47 AM
  3. Replies: 21
    Last Post: 04-17-2006, 07:02 PM
  4. Low Brake Pedal
    By ACE_14 in forum 3geez Accords
    Last Post: 11-04-2004, 12:18 AM
  5. Brake pedal
    By Jerren in forum 3geez Accords
    Last Post: 11-13-2002, 03:35 PM
