Results 1 to 22 of 22
Thread: can someone post a performANCE LIST
    Jan 2003
    1986 prelude
    charlotte nc
    HOPING SOMEONE CAN POST A COMPLETE INTERNAl PERFORMANCE LIST FROM OTHER CARS. TAT WILL FIT THE B20A INTERNALS .PLZ POST IM TRYING TO BUILD A PERFORMANCE B20A WITH 250HP NA . IV SEARCHED AND AL OF ITS DISORGANIZed .some people keep sayin naa that dont work so i need a for sure Answer what fits wat with some modification thnx guys.
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: can someone post a performANCE LIST
    First off, you want 250 HP N/A, i would hope you can try to search for yourself (and i know you said you had) and come up with your own answers. Do you own organization and search for your own answers. Squeezing out another 110 HP from an N/A motor is gonna be hard if you cant find your own facts.
    Not trying to be a dick, but this is the second whiny pleading thread that you've made with little or no effort on your part. Not even gonna attack the grammar/CAP ISSUES (oops i may have anyway)
    '89 SE-i Coupe
    Awaiting Garage
    2drSE-i's Avatar
    Oklahoma City
    took me 30 seconds to find, literally. Lists pistons, rods, bearings, valves etc.
    https://www.3geez.com/forum/showthread.php?t=29259
    Well, I see alot of people asking where to get that part and that part and another part from local USDM cars when rebuilding their B20A.
    I will try to do a list of most of the parts available in the US for your B20A engine.
    Here are the parts and the USDM engine/car it corresponds
    ---------Part ---------- Engine ---- Car------------------
    Axle (Right side) ------ A20A ---- (Need to use a 88-89 Prelude inner joint)
    Camshafts --------------- B18A1 ---- (Acura Integra 90-93 non vtec, some work involved)
    Clutch disc ------------- B20A5 ---- (Prelude 2.0si 88-89)
    Crank bearings ---------- B20A5 ---- (Prelude 2.0si 88-91)
    Crank sensor assembly (1) B20A5 ---- (Prelude 2.0si 88-91)
    Crank sensor assembly (2) D16A1 ---- (Acura Integra 86-87) *used with a Vacuum Advance Accord ECU*
    Distributor assembly (1)- B20A5 ---- (Prelude 2.0si 88-91)
    Distributor assembly (2)- D16A1 ---- (Acura Integra 86-87) *used with a Vacuum Advance Accord ECU*
    Exhaust manifold gasket - B20A5 ---- (Prelude 2.0si 88-91) *stud holes do not match perfectly, can be easily fixed*
    Intake manifold --------- A20AX ---- (Accord 86-89)
    Intake manifold gasket -- A20AX ---- (Accord 86-89)
    Pistons ----------------- B20A5 ---- (Prelude 2.0si 88-91)
    Piston Rings ------------ B20A5 ---- (Prelude 2.0si 88-91)
    Pressure plate ---------- B20A5 ---- (Prelude 2.0si 88-89)
    Rear main seal ---------- B20A5 ---- (Prelude 2.0si 88-91)
    Rods -------------------- B20A5 ---- (Prelude 2.0si 88-91)
    Shift rod seal ---------- A20AX ---- (Accord 86-89)
    Spark plug wires (1) ---- B20A5 ---- (Prelude 2.0si 88-91) *use with B20A5 distributor*
    Spark plug wires (2) ---- B18A1 ---- (Acura Integra 90-93) *should be fine with the JDM Accord/86-87 Integra distributor*
    Starter assy ------------ A20AX ---- (Accord 86-89) *With auto transmission*
    Throw out Bearing ------- B18A1 ---- (Acura Integra 90-93 non vtec)
    Valves ------------------ B20A5 ---- (Prelude 2.0si 88-91)
    Valve Cover gasket set -- B20A5 ---- (Prelude 2.0si 88-91)
    Valve seals ------------- B20A5 ---- (Prelude 2.0si 88-91)
    Water Pump Assembly ----- B20A3 ---- (Prelude S 88-89)
    That list is far from complete. I do have more I need to post (have it written somewhere)
    Feel free to submit the parts you find.
    '89 SE-i Coupe
    Awaiting Garage
    *waits for rjudgey to chime in*
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    does it really matter what parts fit or not??? I mean, if you want 250 NA then most of the parts will most likely have to be custom made..
    -Gio
    My E85 Turbo Build
    5280FEST
    get some cams bro.
    other members on here have:
    B16A2 intake
    B16A High compression pistons (mod wrist pin size to fit them) good for 11:1 compression ratio i think.
    you can even use h23 rods in the motor so you can get aftermarket. (once again the wrist pin size differs)
    modded h22 headers or b20a5 headers made to fit.
    OBD1 swap
    SOHC F22 adjustable cam gears X2
    rjudgey style head work ftw
    yeah i just listed what i want on my car, im half way there too, all i had to do was search long and hard :)
    A Mile High.
    get some cams bro.
    B16A2 intake
    OBD1 swap
    b16 pistons?? they fit the a20?? :dunno:
    -Gio
    My E85 Turbo Build
    5280FEST
    LX User OldSkoolA20accord's Avatar
    Apr 2008
    88 Accord DX
    limestone, TN
    the a20 bore size is like 82.67mm the b16 is 85mm i believe.
    88 DX hatch.
    2drSE-i's Avatar
    Oklahoma City
    theyre talking about the b20
    '89 SE-i Coupe
    Awaiting Garage
    Apr 2008
    88 Accord DX
    limestone, TN
    oh ok my bad. i was wondering why it said f22 adjustable cam gear X2. lol. Where do you get the b20 engine and tranny for our car?
    88 DX hatch.
    2drSE-i's Avatar
    Oklahoma City
    From JDM/EDM/CDM accords. Good luck finding one, they are pretty rare.
    '89 SE-i Coupe
    Awaiting Garage
    Jul 2008
    1989 LX Coupe 5 speed
    Rothesay
    Quote Originally Posted by OldSkoolA20accord View Post
    Cant you find them out of a [3rd? or 4th gen?] prelude? Not shure but someone told me this.
    89 LX Coupe - 5 speed
    84Accord's Avatar
    Jun 2008
    1984 Accord LX
    Quote Originally Posted by 3Gee_Dub View Post
    itd be in a 3rd gen prelude? but the ones in the preludes are a b20a5. not a b20a1
    2drSE-i's Avatar
    Oklahoma City
    no you cannot get them out of any preludes except for maybe the 2nd gen preludes, but b20a powered preludes are even more uncommon than accords.
    If you try and get them out of the 3rd or 4th gen preludes they will not fit. Totally different mounts, and the engine tilts the other way under load.
    '89 SE-i Coupe
    Awaiting Garage
    what? so those lean back engines, when you gun it, they tilt foward? how's that?
    crank shaft turns backwards in cars down under? toilets flush counter clockwise?
    A Mile High.
    :rofl:
    -Gio
    My E85 Turbo Build
    5280FEST
    A Mile High.
    :rofl:
    -Gio
    My E85 Turbo Build
    5280FEST
    what is the bore of an b20?
    81mm
    Jan 2003
    1986 prelude
    charlotte nc
    wait so the b16 stock pistons work or any aftermarket ones , and h23 rods ok got what rod and main bearings do i use if i do that, also
    wat cams are out there fit our b20a or just colts
    Jan 2003
    1986 prelude
    charlotte nc
    Yes Or No
  1. Performance parts list . 86-89 accord
    By obdriver6 in forum Performance
    Last Post: 11-02-2022, 02:40 PM
  2. b20a complete performance list
    By b20a86lude in forum JDM B18A / B20A Swap Tech
    Last Post: 12-08-2008, 09:38 AM
  3. Ok guys, post your mods list
    By AccordEpicenter in forum Classic Honda Community Chat
    Last Post: 05-21-2004, 03:34 AM
  4. List of performance parts!
    By macius in forum Performance
    Last Post: 10-28-2003, 05:38 PM
  5. performance radius rob bushings post old site please
    By 89lxihb 00lude in forum Performance
    Last Post: 09-15-2002, 01:19 PM
VigLink badge
