Results 1 to 4 of 4
Thread: I need help replacing Battery cables
    DX User 314lxiSleeper's Avatar
    Sep 2008
    86-Honda-Accord lxi
    St.louis
    i just recently took off my batery cables . i dont know why my new calbes wont work . Does the negative cable have to be grounded 2 times .? if so where at ?
    thnks
    Re: I need help replacing Battery cables
    if there was two you took off then yes you may have to replace both of em. Make sure you have a good ground scrap it a bit if you have to. Just replace em like you took em off.
    Rendon
    The ground wire from the battery runs to the body, then from the body to the clutch cable bracket.
    Sep 2008
    86-Honda-Accord lxi
    St.louis
    Alright thanks for the help guy i really appreciate it
  1. Battery light still on after replacing battery...
    By offthahook in forum 2geez Accords
    Last Post: 09-23-2007, 08:42 AM
  2. Replies: 19
    Last Post: 01-15-2007, 04:12 PM
  3. grounding cables
    By pervasto in forum Performance
    Last Post: 07-02-2004, 11:08 AM
  4. where should I run my cables??
    By AD9SloAccrd in forum Interior & Exterior Care
    Last Post: 05-09-2003, 06:38 PM
  5. Cables
    By sanjay in forum Interior & Exterior Care
    Last Post: 09-04-2002, 01:57 AM
