Okay... I'm getting what I would describe a tapping noise only when I am accelerating. I can only hear it till around 2700rpm due to engine noise or it stops. Could this be my valves?
could be
adjust the valves and see if it goes away
https://www.3geez.com/forum/showpost....51&postcount=2
does it make a knocking noise when you first start it from "cold"?
Not that I can tell. But starting it is a whole other issue. I think my starter is bad or there is a bad connection somewhere. It only knocks or taps when I am pushing the accelerator.
what grade of gas do you use?
could be pinging
Just good old regular. I had thought about that. I'll have to try a higher grade whenever i go empty again. Just filled up last week so it could be a few more weeks before its empty again. I only drive 14 miles a day and i just had my wisdom teeth pulled today so i won't be driving at all this week.
try using 92 octane
my car makes a click when you touch the throttle at idle, its was pinging, If the gas doesnt fix it you can try retarding your ignition timing.
Sometimes cars just do it and it doesnt go away, take my car that used to be automatic for example, i cant get rid of the knock even tho its manual now.
Seems autos like to ping....
mine is a 5speed and like i was saying it only does it while driving. If I am sitting at idle and press the gas it doesn't do it. It will be a couple of weeks before I run out of gas.
6 wat damn that shit aint gold lol.
yup...the girl i was wish just made fun of me...oh well now i just put in 91 shell gas
