Results 1 to 12 of 12
Thread: Suspension overhaul but.............
    LXi User AC439's Avatar
    86 LXi
    FL
    Question Suspension overhaul but.............
    I'm planning to fix the worn suspension components. I know I need UCA/balljoints and struts. But due to the current poor economy, I have to do them in phases. I'd like to change out the UCA first, they have bad ball joints. The next phase I want to change out the struts.
    I really hate taking apart ball joints and I don't want to do them twice. I will probably break them if I have to take them apart. So my question is: do I need to disconnect the UCA balljoint when removing front struts?
    Thanks.
    -AC
    Re: Suspension overhaul but.............
    No. They aren't attached to each other in any way.
    Apr 2007
    1988 Accord LX 5spd
    By the way the upper ball joints are part of the A-arm there welded too it.
    If you didn't already no this.
    86 LXi
    FL
    Thanks guys for replying. Yes, I'm aware that the UCA and ball joints are integrated. BTW, I read somewhere here that I need an offset wrench to take the nuts off the left side since it is kind of hiding under the wiper motor correct? How much time would I anticipate for the job? (I'm going to get a pickle fork to get the old ball joint off, never have any luck with hammer)
    -AC
    I've had good luck removing extraneous stuff around the bolt, using a socket extension and a swivel socket.
    Kragen loans front end kits with all the tools you need to remove those ball joints. If you don't want to damage the boots with your pickle fork, just get the kit.
    May 2008
    Do it all at once. Just save up.
    May 2008
    Kraken?
    Quote Originally Posted by jdmaccordnut View Post
    Kraken?
    kragen, shucks. were are you located
    Oct 2008
    '89 LX-i
    Kragen on the east coast is known as Advance Auto I think. They have the same website. Hope that helps. The website is www.partsamerica.com and www.kragen.com.
    Z
    '89 Honda Accord LX-i, 254k+ (as of 8/26/09) mi, black sedan, original engine, bone stock, Automatic, temperamental.
    Quote Originally Posted by AC439 View Post
    -AC
    I can use a long extension to get the top bolts on the drivers side. On the passenger side I have to move the MAP sensor out to get at them.
    https://www.3geez.com/forum/showthread.php?t=64456
    post #6 i got a good deal on the UCA and so far with a grease fitting added they are working great.
    86 LXi
    FL
    Unhappy Re: Suspension overhaul but.............
    Thanks guys for information !
    Yeah, I wish I can get all done at the same time but my funding is limited (especially with the current poor economy) so I just can't spend too much for everything. I'm pretty sure all my suspension components are stock original and the car has 256k miles and things are starting to fall apart. I do need to replace all struts so I'm thinking doing UCA with struts at the same time at the most and leave the LCA/ball joints later. So, I need to replace those that are more severely broken first. Not to mention that the car needs a new windshield (a crack) and a paint job (screwed up by Maaco).
    -AC
    May 2008
    Never go to Maaco. EVER.
  1. Front suspension bushing overhaul
    By codyJDM in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-25-2012, 06:46 PM
  2. Suspension overhaul questions
    By 89GhostLxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-12-2012, 03:20 PM
  3. Trunk overhaul
    By mkymonkey in forum Interior & Exterior Care
    Last Post: 03-04-2008, 08:35 AM
  4. Transmission Overhaul
    By djcslice in forum 3geez Accords
    Last Post: 05-12-2006, 02:08 AM
  5. what is a carborator overhaul?
    By Mike Me-z in forum Carburetor Tech
    Last Post: 10-11-2002, 01:01 PM
