Results 1 to 6 of 6
Thread: idle and engine light questions
    DX User Andagail's Avatar
    May 2008
    1989 Accord LXi
    North Central Florida
    Smile idle and engine light questions
    Hi. Recently my car has been running funny. When I start up, the needle on the tachometer thing moves up and down between the 1 and the 2. It sounds like I am pushing the gas rhythmically a little bit. It stops after a while.
    Second question: The day before yesterday the check engine light came on. It was only on for that one day. I was told to get some seafoam and put it in the gas.
    I am still trying to get up the money to get my brother to work on other things, like the axles.
    Any advice to pass along? I really don't understand cars, but I try.
    Oh, I have an 89 LXi coupe fuel injected
    Thanks, Andagail
    Jul 2008
    1989 LX Coupe 5 speed
    Rothesay
    Re: idle and engine light questions
    Quote Originally Posted by Andagail View Post
    Thanks, Andagail
    How often do you get tune ups? it may be time for one.
    89 LX Coupe - 5 speed
    Do a good tune up and IM pretty sure its your ICV "Idle Control Valve". Mine was dirty as hell just be carefull taking it apart OR you can just take the top 2 screws off and Turn it down to the idle is fine BUT. that gasket is old so if it breaks your fucked and you would have to get another one. Ive had this problem before so thats prolly what it is man. and if you dont know where your ICV is its the only Valve thats on the rear of the Plenum or people call it Intake Manifold. Hoped i helped
    Rendon
    The bouncing idle on injected cars typically is caused by two things. The first is low coolant. If it is low, you'll need to fill and then bleed the cooling system properly.
    The second cause is a vacuum leak. It could be that your idle adjustment screw is out too far allowing too much air into the idle circuit. Try tightening that next. Otherwise, you'll need to check your vacuum lines individually for leaks.
    Let us know what you turn up.
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    I would first check for vacuum leaks; a large enough leak would cause exactly the bouncing idle. Mine (86 LXi) had a vacuum leak in the power brake booster; I knew it was broken because I needed to press really hard for the brakes to work; plugging the hose going to it solved the bouncing idle.
    MY ICV needed adjustment too; once the bouncing idle was gone the engine would idle way too high (but not bounce). All little things that need attention in old cars.
    You may get a set of rubber plugs at any parts store. Remove vacuum hoses one at the time, plug it and see what happens.
    Feb 2009
    1988 Honda Accord LXi
    Southern Pines NC
    Okay if yours is the same as mine, you have to check under the driver side seat for a little box which is best to look at from behind, there will be a little plastic "door" that you open to see a flashing light, that will be the code for the check engine light and you should be able to get a generic Idea of what the problem is just by using everyone buddy Mr. Google.
    As for the Surging Idle I am havng the same problem on mine at the moments and am in the process of getting this fixed. I originally thought it was the Idle air Control and cleaned that out but it seems it is not the problem. I work at a shop and the next thing recommended for me to do would be to unplug the TPS or THrottle position sensor, and when I did the car will default to a standard value and the Surging Idle stopped. so that appears to be problem with mine.. One thing with that is that Honda was brilliant in the way of designing this so that you couldn't replace just the Sensor. It is riveted into the Throttle body and the whole thing must be replaced. I called honda and it happens to be a cool $380 dollars. I got one off of ebay with tthe sensor for like 81 dollars and I will let you know how things go from here..
  1. WTF, Honda? check engine light/idle
    By jg09 in forum EFI Tech
    Last Post: 11-22-2009, 07:09 PM
  2. Check Engine light and Rpm Idle
    By ShyBoyCA6 in forum 3geez Accords
    Last Post: 11-06-2009, 07:02 PM
  3. Check engine light and other random accesory questions
    By Lockleaf in forum Classic Honda Community Chat
    Last Post: 03-13-2006, 04:21 AM
  4. Check Engine Light - Erratic Idle
    By ITLRUN in forum EFI Tech
    Last Post: 10-15-2005, 05:21 AM
  5. eratic idle, engine light, and clicking from tranny
    By Tref_LXI in forum 3geez Accords
    Last Post: 06-14-2003, 12:09 AM
