Results 1 to 4 of 4
Thread: Window motor brushes
    LX User G. White's Avatar
    Sep 2008
    1989 Accord LXI
    Buckeye, AZ.
    Does anyone know where I can find replacement window motor brushes? I took the motor apart and cleaned the contacts/ lubed the window tracks, it worked better until the contacts got dirty again. I think it would be more economical to change the brushes because everything else looked good on the inside of the motor. Thanks guys.
    Re: Window motor brushes
    Probably will need to spring for a new motor assy. Rock Auto has them for $50-$100.
    Vanilla Sky's Avatar
    1999 Penalty Box
    Hit a junkyard and grab a bunch of brushes from rear windows. Typically, the rear driver's side is the one least used.
    look in the yellow pages for someone who rebuilds electric motors, usually they can find something that works. those brushes can be ground to fit if needed. even the hardware stores may have electric motor brushes.
  1. troubleshooting window motor/wiring
    By paul in forum 3geez Accords
    Last Post: 02-04-2009, 07:54 PM
  2. Need brushes for Mitsuba Motor cooling fan
    By nswst8 in forum EFI Tech
    Last Post: 05-25-2008, 10:16 AM
  3. Failing window motor or relay?
    By poor_red_neck in forum 3geez Accords
    Last Post: 11-04-2007, 03:46 PM
  4. Window Regulator/Motor
    By SILENT in forum 3geez Accords
    Last Post: 06-12-2007, 03:46 PM
  5. WTB: window motor
    By kotseko in forum Trading Post
    Last Post: 10-27-2003, 10:10 AM
